Old 10-08-2012, 04:50 PM
occory occory is offline
Mein Auto: 04 745li
Coolant Leak at rear of engine block
After countless updates to the coolant system and repairing all the notorious engine oil leaks, I just found out today that a brand new coolant leak was discovered at the rear of my engine block. Coolant is visable at the opening at the bottom of the bellhousing (where the trans and engine come together). The same spot a leaking rear main seal would leak. The coolant is not coming from above as orginally suspected "valley pan". Not sure if it's good news or not, now the trans has to come out and the flywheel comes off to repair the leaking coolant plate at the rear of the engine block. Will install new flex disc and rear main seal at the same time.
I've had the car for just over 5 years, and currently have 120K on the odo. The car has been expensive to keep up since out of BMW's extended war, almost 2 years ago. I would guess $3K per year since out of war. However the car still drives better than any other new car I have driven, execpt maybe a new F01.
Old 10-08-2012, 05:50 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
That sucks to hear
How much are you looking at in repairs for this?
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 10-08-2012, 06:10 PM
Mein Auto: 04 745li
Bust out another thousand!
Old 12-21-2012, 07:48 PM
7ELEVEN 7ELEVEN is offline
Mein Auto: 2002 745LI
occry, did it turn out to be the "coolant plate at the rear of the engine block"? I have found my leak today in the same spot you described. I could watch it dripping inside the bell housing.
Old 12-22-2012, 07:58 AM
MDuke77 MDuke77 is offline
Mein Auto: 745i
I had my lower valley pan replaced recently do to a leak. indy charged $800. I think this is the pan you are referring to. Good luck.
2006 750LI
Old 12-22-2012, 11:15 AM
I believe I found my problem and the one that OCCRY was referring to. Within the bell housing on the back of the engine block there is a fluid passageway. It has a cover with a molded in rubber gasket. That gasket goes bad and leaks inside the bell housing.
See this diagram at realoem.com it is item #5
http://www.realoem.com/bmw/showparts...51&hg=11&fg=10
The video on this page is how I figured it out.
http://www.bmpdesign.com/technical/c...62_Engines.php
Notice that if you were to have a valley pan gasket leaking in the rear of the engine it would leak above the bell housing. The leak would run down and around the outside of the bell housing.
Time to start getting ready to pull the transmission!
