E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Yesterday it started missing BADLY; What would you DO before hitting the shop?
2002 Automatic 325 Ci @ 85k miles...
I was out of town for 3 months. The car was in the garage during this time and it never cranked up. I charged the battery and started it up yesterday, engine sputtered a bit at first (should be normal after 3 months); held down the gas for about 10-15 seconds at 1000 rpm and it picked up. I drove the car right after that. It drove fine for about 25 miles and then all of a sudden started missing badly. I barely made it home (was about 3 miles out when it started). It misses badly at idle and throughout the speed range. I almost feel no power in the car. It was as if 184 hp motor became 30 hp. Acceleration after a stop is terrible. Tried to floor it a few times, engine sputtered so bad. It didn't help at all. My code reader says: P0171, P0174 and P0313 (Cyl#3 misfire with low fuel) P0171 and P0174 were there for a long long time. They have been coming and going occasionally. I checked many things for those codes but couldn't find the exact cause. Though I never felt any difference in the car the whole time. Engine was running okay, the car was driving fine... P0313 is the new code. It says cyl #3 misfires due to low fuel but the gas tank is full. Plus it feels like more than one cylinder misses. I will have to take the car to a repair shop tomorrow in the afternoon most likely. Meanwhile, if you could give me some suggestion, I would take it... In this limited time, here is what I checked: -Checked the intake boots. No crack or torn part. I wouldn't expect to see because both of them replaced a few years ago during maintenance. -Removed and cleaned the MAF. -Removed the #3 spark plug. It seemed just fine. No crack on the ceramic body and the tips were very clean. I know it could be many many things but if you know any component that I should check, I would do it with a heart beat... Hard for me to believe that this happened because the car sat for 3 months w/o running. Thanks in advance...
Switch your ignition coil from another cylinder and see if it misfires on #3 or the cylinder you switched the coil from.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
I liked that IDEA guys!!!!
I knew you guys would come up with something to try but wasn't expecting something this simple to do... Will do it first thing in the morning and report back... |
let us know.
Mal, Smolck,
I did the test. Bingo!.. Misfire code follows the coil. I did it on two other cylinders and everytime it followed. Though I gave a wrong info in my original post. It shouldn't matter much but I would like to correct it. The problem coil is the one on Cylinder#1 NOT #3 and the associated code is P1343 (Cyl#1 Misfire with fuel cutoff) NOT the P0313 misfire with low fuel. The misfire code (P0313) for cyle#3 is unrelated to this incident and probably was in the DME for a long time and I forgot to clear it. When I pulled the codes yesterday it showed both P0313 and P1343. I thought the P1343 wasn't related because my scanner was saying "Manufac. Specific Powertrain Code" I should have searched for it. My bad... This morning, I swapped the coils between #1 and #3, then I got P1347 (Cyl#3 misfire with fuel cutoff) because I moved the bad coil from #1 to #3. Then I repeated the test once again. This time I moved the bad coil to #2 and I got P1345... Now, I am thinking I found the problem with your guidence. I checked the Autohausaz for the coils and they have 2 brands: http://www.autohausaz.com/search/pro...gnition%20Coil Should I buy the expensive one? And I do not need to replace all of them as the note at the bottom of URO says right? Last edited by iskoos; 10-09-2012 at 04:35 PM. Reason: typo |
$25s! that's not bad at all.
$25 is definitely a deal but I talked to someone and he told me about a store in Orlando. I will check with them and see what they have.
If I order one, I will have to wait several days. I am currently grounded. The car is NOT driveable... Smolck if I want yours, could you do USPS priority mail by the end of today? With that I will have it Thursday. But I will still try the store in Orlando first... I will let you guys know... |
Well I checked the local stores and bremi/OEM is $75 each. As much as I like saving money by ordering it from Autohaus (or even better from smolck), I unfortunately can't afford to get grounded a few more days. So I had a friend purchase one for me from a local autopart store...
I will install it tonight and let you guys know. Hopefully it will be the fix... |
Okay guys Thank you. It's been fixed. The Bremi coil came w/o a boot. It was showing it clearly on the website that it didn't have a boot but I didn't pay attention. It worried me a bit to remove and use the old boot from the defective coil but I had no other choice at the time being. I transferred the boot to the new coil and installed it.
Car started up immediately. I got a few hesitation at first but I generally have that at each cold start. After warming up the motor, it all went away. I test drove the car in the neighborhood and it drives just fine. Thank you so much Mal and Smolck. You guys saved me tons of money ![]() Now the question is considering the age of the car, are the other coils in the queue to fail? |
I had an old spare car for years and with that car working, I would tackle DIYs much easier. After that car stopped running (auto tranny ), I am not as willing to perform DIYs anymore. Maybe one day when Smolck retires from his job and decides to setup his mobile repair van and hits the roads, I will let him do my Vanos seals |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
