E46 (1999 - 2006)
Old 12-03-2009, 09:00 AM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Alternator bearings noise
What is the cheapest way to change this?
Old 12-03-2009, 09:06 AM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
Are you sure it's the alternator? The tensioner pulleys seem to have a higher failure rate, and they are a cheaper/easier fix than going after the alternator....
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'92 M5 Touring - BL01001 - first M5 Touring ever built
2017 M2 V887285 - Mineral Grey, 6MT
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 12-03-2009, 11:11 AM
fcpeuro's Avatar
fcpeuro fcpeuro is offline
Sponsor
Mein Auto: All BMW Everything
+1
Take the belt of the accessories and spin the tensioner wheel. It is more then likely the wheel.
Quality & Service, Guaranteed for Life
FCP Euro - European Auto Parts Online
sales@fcpeuro.com
Old 12-03-2009, 12:00 PM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Originally Posted by Andrew@FCP View Post
+1
I have already changed the tensioner wheel, and the v belt.
With a hearing aid we have concluded that it is indeed the front bearing of the alternator that is making the whistling noise.
Now I have to take out the alternator and take it to an electrician for installing new bearings, or buy a new alternator, or buy a second hand one.
Old 12-03-2009, 02:48 PM
3beemers 3beemers is offline
Mein Auto: 01 330i 09K13GT 83R100RS
If you have that option where you live, that is good. Might as well replace the rear bearing and check everything else (armature, field, etc.).
Old 12-03-2009, 03:15 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Idler pulley.
Old 12-04-2009, 06:52 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Originally Posted by smolck View Post
Idler pulley.
I just changed that with a new part, and the sound still continues.
Old 12-04-2009, 05:25 PM
LX-biker LX-biker is offline
Mein Auto: 2004 325XI Sport pkg
Hi Recently changed all pulleys and waterpump. Now I have whining noise when A/C engaged only! Try turn it off when you hear whine. Before I had two pulleys dry and going waterpump. So, it was dry bearings orchestra. So now I book appintment with dealer since I really don't want mess with pressure gauges and refrigerant. Plus I can't find in Canada canned R134 for try recharge cooling system. Here available Duracool R12 only, but I will try it when it last thing before dump car at junkyard.
Old 12-04-2009, 08:18 PM
ventsyv ventsyv is offline
Mein Auto: 03 BMW 330ci
I have a noise coming from that area too. I thought its the alternator but then I decided it was the pulleys. I took the deflector pulley off and sure enough the bearings on that were bad. I think I'm having the same problem with the tensioner pulley. If you are sure its the alternator, I think you can change just the pulley.
Old 12-04-2009, 08:28 PM
Ryan M Ryan M is offline
Mein Auto: .
You can change the pulley, but the bearing is not pressed into the pulley like on the idler or tensioner. The bearing is part of the alternator.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 12-04-2009, 08:36 PM
That sucks. If you can have someone replace the bearing... but it might be cheaper to get a new one ...
Old 12-05-2009, 12:33 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
There you go:
No 1 is making the noise most probably.
So far I have changed no 1 and no 6 from the bottom drawing.
Also note the following:
1. I have the mechanical tensioner not the hydraulic one as shown at the drawing.
2. when I pour water at the pulleys it stops and then continues.
Old 12-05-2009, 04:25 PM
mekaneck mekaneck is offline
tool
Mein Auto: 2003 325xi, 2007 X3
I'd say change #15 from the bottom pic, but if you are sure it's the alternator, then you best get a new alternator. #1 from your upper pic can't make noise unless the belt is slipping over it. It doesn't contain a bearing or anything, it is purely a puller mounted to the rotor of the alternator. So if the sound is coming from that pulley, it means your mechanical tensioner isn't providing enough tension in your belt, or a bearing is bad in your alternator.
2003 325xi BlackČ
Old 10-09-2012, 03:18 PM
wellssh wellssh is offline
Mein Auto: BMW 2003 325i
Same issue, replaced A/C, idler and tensioner pulleys, as well as the belt. Only thing left is the alternator pulley.
I'm guessing I can't just replace the pulley and bearing on the alternator, is that the consensus???
