E30 (1982 - 1993)
Old 10-09-2012, 05:30 AM
Terrains's Avatar
Terrains Terrains is offline
Mein Auto: 1987 BMW 325e
Unusual Coolant Consumption
Here I was beginning to think I was problem free for a while Anyways, I've noticed a large amount of coolant just disappearing after about a week and a half. I fill her up to the fill marks, and about a week later, I have to fill her up again. Where should I start looking? I don't visually see any leaks anywhere, and the oil isn't cloudy or anything.
Old 10-09-2012, 05:48 AM
Gasturbine Gasturbine is offline
Mein Auto: '87 325i Cabrio
If your sure its not leaking (could be leaking when running only), and its not in the oil, its going out the tail pipe...you have a blown head gasket, or worse, cracked block.
Old 10-09-2012, 08:12 AM
hornhospital's Avatar
D'oh, You Kids!
Cracked head: good possibility. Cracked block: extremely unlikely. The head is aluminum and can be prone to cracking if overheated. LOTS of them have cracked. The block is cast iron. I've never seen a cracked M20 block. Not saying they can't, but it's pretty rare if it is.
Quotes to live by:
Old 10-09-2012, 08:39 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
Pressure check the cooling system see if you are losing pressure. You can pull the spark plugs and do a cylinder leak down check and see if you are losing pressure. Look for pressure build up in the cooling system. You can even check for gases in the cooling system. The easiest thing to do is look to see if bubbles are coming out of the cooling system and not stopping and then pull your spark plugs to see if they look like they have been burning coolant.
Old 10-09-2012, 07:25 PM
downhiller's Avatar
livin large
i had a leak from the throttle body that sounds exactly the same. one of the coolant lines had a small leak and since i drove alot of highways, never noticed a smell or drops. best bet would be get the engine up to temp and with it running look in the tight areas for leaks, throttle body, heater core, all the hoses.
Old 10-09-2012, 08:22 PM
BMWFatherFigure's Avatar
Old School
All bases covered on the replies above. Either you burn it or leak it.
Current:
E38 Parts Car
Previous:
Old 10-10-2012, 06:07 AM
Terrains's Avatar
Alright, thanks everyone! Off school today, so I'll be out there trying to figure this out
