Old 10-09-2012, 09:52 AM
Sequence Sequence is offline
Mein Auto: 2001 525i
Car won't start
Got back from a 3 day trip and I go to start my 01 525i and it won't start. I thought it was just gas because I was a little low before I left. But when I filled it with a couple gallons, it still wouldn't start. At 1st it didnt make a sound. Electronics came on fine, but nothing in the engine department. Then after about the 3rd time, I heard a slight "moaning sound", and electronics lights were dim. I'm thinking it could be the battery but I'm not sure. Any ideas?
Update: I just bought a battery from autozone. After checking out, he told me I would have to take it to the dealer to get it "flashed" and it will probably cost an additional $100-$160. Is this true?
Old 10-09-2012, 11:05 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
Battery, jump start it.
You probably have battery drain, number 1 cause is the FSU. If you search on here you'll find a lot, inc a DIY on how to replace it and info on how to diagnose battery drains.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 10-09-2012, 11:08 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
If you've not noticed erratic blower performance, or none at all, probably not the FSU. Another failure symptom is inability to control the blower speed.
Battery s/b at 12.5+ after setting overnight. With engine running, s/b 13.5+. Measure and report back.
Old 10-09-2012, 11:14 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
e39 does not require registration or flashing
Only f10 newest five.
Old 10-09-2012, 02:44 PM
Great...Just replaced the battery. Problem solved!!! Thanks
Old 10-09-2012, 02:57 PM
I'd strongly recommend you check for a battery drain, put an amp meter between negative on battery of car with car locked, wait 16 minutes for it to go to sleep and check the current is ~40mA. (There is good guide on here)
I had a leak on my car, put new battery on it not knowing I had a leak. Everything was fine for month or so, until i didn't drive it for a 2/3 days*, then the battery was flat again. Letting the battery go flat isn't good for it, so you damaging your nice new battery if it happens.
Old 10-09-2012, 08:18 PM
Did you find out where your leak was coming from?
Old 10-10-2012, 07:05 AM
Yes, it was the AC Control panel that I'd replaced after my original one died. The second hand unit I bought had a fault. Very very unlikely to be the same issue on yours.
It may have just been your battery but for the sake of a few minutes it best to check rather than get stranded somewhere.
Old 10-10-2012, 09:52 AM
Well My LCM is having problems so it could be draining battery slowly. I have a new LCM in hand ready to be installed as soon as I fix the seals on my Sunroof + Windshield.
Old 10-10-2012, 09:55 AM
LCM/LKM needs to be coded to work correctly.
Old 10-10-2012, 09:59 AM
Yeah I've already got a guy who will code it for me. The Tamper dot is "undesirable" in the eyes of many, including myself
Old 10-10-2012, 12:03 PM
You could check at the battery for a leak if you concerned or modify a fuse so you measure a the current following through a circuit and still that in place of the fuse for the LCM/LKM.
