X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
Wiper Chatter
We are receiving some significant rain today in the Mid-Atlantic and my wipers are chattering like crazy.
Back in August when I had the car in for an oil change, the dealer installed new OE replacement wipers. This is the first time I have driven this car in the rain since the new wipers. Is anyone else having the same experience with the OE replacement wipers chattering? I was planning on installing Bosch Icon wipers at some point in time. Now, I might be getting them sooner than later. Thanks
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog 1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb BMW CCA #422951 |
http://www.autobarn.net/piwiblre.html Never had the problem since (over 3 years). They last much, much longer, and perform really well. These refills fit in the X3's wiper blades perfectly (they don't fit all types of blades). I'd be wary of using Bosch Icons on the X3. You would lose your anti-lift aerofoil on the driver side. From most accounts they might look great, and work well enough initially, but they don't last too long, and they are throwaways. |
I had the exact same problem with mine after my service visit. What the dealer is calling OE refills are not really OE refills. They are cheap snip-to-fits. This is another area where we got cheated by BMW.
http://www.bmwtis.com/tsb/bulletins/...p/B610603g.htm http://www.bmwtis.com/tsb/attachment...structions.pdf |
My wipers have always stuttered or chattered even when it is raining buckets. I have a low-mileage car so they are basically new. I may give up and go with a BETTER BRAND.
Pretty cheeeeeezy behavior. |
Eventually I'll have to go with PIAA's I guess. |
The same thing is happening now on the 3er models, as I noticed the ones the dealers replaced on my mom's 325i aren't the same as what comes from the factory.. Hence, the worse wiper performance. I went to the Bosch.de website (Bosch is the original supplier from the factory) and found the fitment model numbers. Of course, the file is conveniently too large to upload but here's the model numbers: X3: 346S (driver with spoiler), 346 (passenger), H351 (rear) Whatever you do, don't use Rain-X. Made that mistake with my mom's car and it was a pain to remove. Last edited by AzNMpower32; 09-30-2010 at 03:54 PM. |
Heh. The chatter is killin' me right now, but I just can't bring myself to cave in and buy something that they should be providing. Guess I'll have to suck it up.
"You will have goosepimples." - Kay Segler, Ph.D. |
Do This First
had the same issue - in my case the blades weren't inserted/installed correctly - ask the dealership or your servicer to check this first - I do have some chatter now but only the rear wiper .
They have always been a bit iffy in moving the water away but now they are chattering. Maybe I received a bad batch. As far as I can tell the back one is fine although I rarely use it. |
I bought a used 2007 a few months back that apparently had brand new inserts put in at the dealer under maintenance warranty. They chattered terribly. I ended up putting the Bosch Icons on and they work great. I also had the windshield replaced since it was ridden with stone chips and in my state, insurance covers windshield replacement with no deductible. I think that may have helped as well.
So: Try the Icon's, and maybe clay bar your windshield to get all the grime off. |
I'm a fan of the Icons. I have a set on my G35x and they have lasted 4 years and over 100,000 miles on the road.
http://www.bonami.net/ProductDetails...ductCode=04036 BMW even issued a bulletin on it many years ago: BMW Service Bulletin Bulletin Number: 61 02 94 (3990) Noisy Wipers, Poor Cleaning: Group 61 Electrical Woodcliff Lake, NJ May 1994 Product Engineering SUBJECT: Windshield Wipers Are Noisy Or Do Not Clean Properly MODELS: All Situation: Windshield wiper blades may start to make noise, or fail to clean the windshield properly, even though the blades are not worn and are properly adjusted. This can be caused by contaminants on the glass, such as oily road deposits or wax residues from car washes. These contaminants can cause the blades to chatter across the glass or fail to wipe cleanly. Correction: Common contaminants that are not removed by conventional glass cleaner can be cleaned with Bon Ami(R), a household cleaning product. The cleaner should be applied on a wet cloth or sponge and the windshield must be thoroughly and evenly scrubbed. Wipe off residue with a clean,dry cloth before the product dries on the glass. Warranty Status: Information only. |
Ok you can cringe at this . . . and I might add I have never had this issue with the X3 . . but in cars gone past if cleaning the glass and changing wiper blades did not fix this the solution is to change the angle of attack of the wiper blades on the glass . . two shifting spanners on the flat part if the wiper arm as far apart as possible and gentle twist - not much . . not much at all . . . I await howls of protest . . but it does work (or did) when I had the problem.
X3 3.0d 2006 (MY07) |
Worst case you have to replace a relatively inexpensive wiper arm. |
GT |
I'm running Bosch Icons with great results.
i just got a set of Icons yesterday as well and runs great...also, it is buy 1 get 1 free at Kragen, here in California at least..
Hmm, my Bosch Icons have been streaking pretty badly despite my attempts to wipe them off carefully to rid them of contamination (grime, sand particles). They're less than a year old.......I think the rubber blade that contacts the windshield is no longer smooth for unknown reasons.
I just bought the Icons last weekend. GREAT wipers. Quiet and they wipe clean.
I had wiper chatter on my X3...replace the wipers this morning with Bosch...raining all day and no more problems.
The best wipers are found by trial and error.
Be wary of using orange wiper fluid and Rain-X on the front windshield. Rain-X is great if drizzle is very light and you are driving fast but is bad for wipers. I think it's good only for the side windows. Consumer Reports did a test and their results are a guide but not specific for our cars. They did say that all wipers they tested are good only for 6 months to a year. They liked the Michelin RainForce and Anco 31 but I found the Anco 31 to be just average, not better. Bosch Icons and Excel Plus were not better. I found the BMW OEM to be great. Saab Bosch OEM wipers work well but they are 22 inches, only good for the X3 driver's side. In fact, they look identical to the BMW original (spoiler, shape, etc.). I also tried Dodge OEM wipers made by Japanese company NWB. They are only ok and they are not cheap. |
#25
I did not like the original BMW wipers but they seem to have settled in and are fine now after more than a year of use. What I do not understand is the timing of the wipers. The intermittent setting appears to be completely random and, in a really heavy downpour, they speed up all on their own.
