E30 (1982 - 1993)
Old 10-27-2012, 04:00 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
Clutch not disengaging? Suggestions?
Hi I haven't been on here in a long while. I now need some suggestions as to why my clutch isn't disengaging.
I have a '84 318i with the stock M10. Long story short The stock M10 had a blown HG. I just recieved a used M10 and installed it a couple days ago. I left the tranny in the car when i pulled the old engine and put the "new" M10 in and it slid onto the tranny just fine. I used the clutch that was already installed on the "new" engine i recieved because i was still good.
I went to move the car and it will not get into gear. When i have it in neutral it rolls fine. With the car off i can move the selector into gear. Obviously when it is in gear it shouldnt move when the car is off. However when i push in the clutch (with the car in gear) it should move but it does not.
This leads me to believe the slave cylinder is bad or there is another culprit?
Any help would be appreciated. Thanks
Old 10-27-2012, 05:54 PM
First time's Avatar
Any help? Really trying to get this thing on the road soon. Thanks again.
Old 10-27-2012, 07:14 PM
downhiller's Avatar
livin large
have you checked the fluid level on the clutch yet? that will tell you something. the shift linkage could also be binding.
also have you tried starting the car in gear with the clutch pedal in?
Old 10-27-2012, 11:47 PM
First time's Avatar
No i will check the fluid level. I recently did my brakes and topped off the fluid. However maybe some air is trapped in the line. I did not try to start it in gear for fear of the car jolting forward suddenly.
If the linkage was binding wouldnt it be difficult to get into every gear? I can get it into 3rd 4th and 5th when the car is off. When it is on, i cant select any gear.
Old 10-28-2012, 02:59 AM
BMWFatherFigure's Avatar
Old School
Bent clutch fork? Bleed the clutch next, then try again.
Current:
E38 Parts Car
Previous:
Old 10-28-2012, 09:12 AM
First time's Avatar
Ok i will do that next. I wasnt able to do anything yesterday. So today hopefully i will have some time.
Old 10-28-2012, 02:07 PM
downhiller's Avatar
livin large
you can start the car left foot on the clutch and right on the brake. thatll keep the car from jumping.
and not always. if its say bent to the right, it could come in contact with the body only in 1st or reverse. and does it grind when you trying to get it in gear?
Old 11-01-2012, 06:11 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Old 11-01-2012, 06:24 PM
downhiller's Avatar
livin large
Originally Posted by Tkaczuk View Post
its how i learned how to ride a dirt bike, or at least learning the clutch on launches.
Old 11-01-2012, 06:25 PM
Tkaczuk's Avatar
That's how I start my car everytime.
Old 11-01-2012, 06:28 PM
downhiller's Avatar
livin large
i never use the brake. but then again both vehicles i drive are autos and my motorcycle is on a paddock stand.
Old 11-01-2012, 06:31 PM
Tkaczuk's Avatar
Haha not that you have a clutch that your in control of.
I have more respect for auto's then I used too. Sometimes its nice to get in your car and not have to shift.
Old 11-01-2012, 08:35 PM
downhiller's Avatar
livin large
somedays. only when someone decides to hit the wall and close 2 of 3 lanes during rush hour. thats when i love the bike, because i have 2 open lanes between the cars
Old 11-02-2012, 01:16 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
How does your pedal feel? was your tob positioned right when you installed the engine?
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 11-03-2012, 05:45 PM
First time's Avatar
Ok guys My problem was solved. Sorry i didnt respond sooner. Been a little busy with other things. Turned out to be the best case scenario. I did do a brake job a little while ago. Then was turned on to the fact that the clutch and the brakes share the same reservior. So the first thing i did was bleed the clutch. Viola! The clutch works fine.
I replaced the starter and now a new problem has arised.
