E30 (1982 - 1993)
Old 06-27-2012, 05:47 PM
nicholasb nicholasb is offline
Mein Auto: 1987 BMW 325E
e30 Hesitation/Shudder
My 1987 325e with an automatic has a serious shudder as its accelerating. It happens between 25-35 mph when accelerating, then smooths out after that. I know at least one vacuum hose needs replaced (Waiting for the part to ship), could this be causing the problem? Thanks for any suggestions!
Old 06-27-2012, 05:53 PM
Terrains's Avatar
Terrains Terrains is offline
Mein Auto: 1987 BMW 325e
You probably have the same exact problem as me. Same car and everything It's *most likely* the driveshaft. Yours might be just the center support bearing and the flex disc/guibo, like what I thought mine was. But mine ended up more serious, the irreplaceable and unserviceable u-joints were bad too. I'm having to get a whole new driveshaft. You can either get the flex disc and center support bearing and take it to a mechanic, or go all in for a new driveshaft
Old 06-27-2012, 09:30 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
All could be fuel pressure, maybe time for a new fuel filter.
Old 07-02-2012, 03:42 PM
Ben T Ben T is offline
Mein Auto: E30 325IS
I have the exact same issue and mine is a 325IS standerd. In mine we replaced the fuel pumps, O2 sensors, fuel injectors, wiring harness, spark plugs and did a fuel pressure testing. They didn't work for me, but they are good things to check on your car if you feel like some general maintenance.
Old 07-20-2012, 05:37 PM
theo23 theo23 is offline
Mein Auto: 1987 325is
driveshaft is probably the issue
Old 11-02-2012, 01:27 PM
I know this thread has likely ended, but I finally solved the issue myself on my car: turns out the ignition coil can be faulty and not show the normal burn marks. Only use the OEM type ignition coil, that may be the issue if you haven't fixed it yet. :P
