parking car for winter - does it need maintenance - Bimmerfest - BMW Forums
Old 09-30-2012, 08:49 PM
bmw1445 bmw1445 is offline
Mein Auto: bmw 525 2007
im parking my bmw 525i 2007 for the winter does it need maintenance ??
Old 09-30-2012, 09:00 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Are we talking 1-3 months or 4+?
1. Get an oil change
2. Put the battery on a tender
3. Gas up and put in fuel stablizer (i'd say for 3+ month storage)
4. Either overinflate tires a little bit than what they are now or jack it up on all corners. (To avoid flat spots)
5. Place moth balls or Irish Spring soap (?) in the car to keep rats away
6. Cover it! Dust =
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 09-30-2012, 09:04 PM
about 4 months .the oil was change aug 25.that should be ok right ??
Old 10-01-2012, 06:34 PM
Dking078's Avatar
Member Supremo
You should be fine.
Old 10-08-2012, 12:26 PM
hey i was talking to some guy owns bmw hey said you cant put fuel stabilizer in the bmw he said it will fuk it up.is that true ???
Old 10-08-2012, 12:30 PM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Why do you park the car over Winter? JW :P
Old 10-08-2012, 12:31 PM
its snow a lot where I'm from and cars 2wd
Old 10-08-2012, 01:27 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
Just get good winter tires and enjoy. I've driven RWD cars for years in the snow - and winters are looooooong here. X-Drive will be nice this winter though.
Old 10-08-2012, 03:25 PM
Damon54 Damon54 is offline
Mein Auto: 545
Who makes a quality battery tender? Hope this is not Hi-jacking cause I would not park one without a tender.
Old 10-08-2012, 08:43 PM
CleanE60's Avatar
CleanE60 CleanE60 is offline
Mein Auto: 2010 535i xdrive
100 % iso alcohol with a full tank of v power or Sunoco 94 if available. Napa should have it.
Keep it clean!
Old 10-08-2012, 09:40 PM
what do you think about fuel stabilizer??
Old 10-08-2012, 09:53 PM
CleanE60's Avatar
If you can look or research the ingredients it's most likely just 100% iso alcohol with a private label, if so then use it, it wont hurt a damn thing. It's Imperative that you know it's 100% meaning no water or.
Keep it clean!
Old 10-08-2012, 10:15 PM
Gilgorm Gilgorm is offline
Mein Auto: 2012 535i X-drive
I've been driving RWD since the 70s and every car has been great in snow but only if you have a good set of snow tires and use common sense. BMWs are lots of fun in the snow.
My current F10 is the first Xdrive I've owned. I'm looking forward to using it this winter.
Otherwise, any suggestions I have, have been covered.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
Old 10-08-2012, 10:50 PM
i have truck for winter lol
Old 10-09-2012, 05:06 AM
CleanE60's Avatar
I have 3 other options between a honda, civic and a jetta. My 535 is also xdrive. but the sand and salt on the streets in CT will ruin your paint and finish. I assume this is the same anywhere else if they treat the road with some sort of ice melting solution
Keep it clean!
Old 10-09-2012, 06:40 PM
k is fuel stabilizer bad for the bmw ???
