The surging in my car is making my blood surge - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 10-09-2012, 07:35 PM
myfirst318 myfirst318 is offline
SSSSMOKIN!
Mein Auto: 95 318is
Exclamation The surging in my car is making my blood surge
I have a 95 bmw 318is, 204000 miles. The problem Im facing happens after 10 to 15 minutes of driving a highway speed (70mph). This is when the rpms on the car get stuck at over 2k. Even when i put it on neutral or even come to a stop, the rpms do not go down, sometimes it move from 2500 to 1500 but usually stay at around 2k. ICV was replaced at around 170k miles. The MAF sensor doesnt look old, but if anyone can show me how the filaments look on a good and a bad sensor, that would help out. Also, any other suggestions are very welcome.
Old 10-09-2012, 07:51 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
Do a short test with bmw tester see if it helps, i need to drive it to give you a better disg
Sent from my Nexus 7 using Bimmer App
Old 10-09-2012, 08:19 PM
SSSSMOKIN!
Mein Auto: 95 318is
ok, ill see if i can get a hold of one and when i do ill post the results, thanks
Old 10-09-2012, 08:22 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
clean the throttle plate, it may be sticky.
df
Old 10-09-2012, 11:32 PM
Si e30 Si e30 is offline
Mein Auto: E36 M50TU
TPS maybe need to replace
Old 10-11-2012, 12:09 PM
SSSSMOKIN!
Mein Auto: 95 318is
Thanks, ill clean the plate n replace the tps this weekend n ill post the results after I do
IT'S ALIVE! never mind...
318is, e36, surging
