E90/E91/E92/E93 (2006 - 2013)
Old 10-09-2012, 07:48 PM
BmwLifestyle BmwLifestyle is offline
Goes with the Flow
Mein Auto: 328xi 2008
What to do if you get the tire pressure sign ( falt monitor sign )
I turn on my car in 38 degree weather for the first time and I got a warming sign . I check the manual and the warning sign indicates if you have a flat tire or loss of pressure . Luckily it was just a lost of pressure in the tires. I'm wondering if I just reset it in the idrive knowing that the tire pressure drop due to the weather or do I have to add the air that was lost ?
Old 10-09-2012, 08:28 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
your tire pressure should be set to the same level regardless of the temp. you need to add air. resetting the monitor just sets the current pressure as the baseline. you do that enough times, the tire will be dangerously under inflated.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 10-09-2012, 08:55 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Re-Badged
Mein Auto: 2013 BMW M3
Refill the tire with air to the proper PSI, THEN reset the TPMS.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 10-10-2012, 07:46 PM
the kidd's Avatar
the kidd the kidd is offline
pay it forward
Mein Auto: X5 and Subaru Impreza
this will happen now with the temps dropping in my neck of the woods. I just got a low pressure left front tire warning and checked all four tires and they were overinflated. I set all four to my preferred settings (34 in front and 40 in the rear) and reset TPMS and BAM! good to go now
2011 X5 SAV titanium silver/black/aluminum
2013 Subaru Impreza graphite gray/black replaced the 335
RIP 335i xdrive DSB/gray
RIP 2005 Subaru Legacy GT
RIP 1986 Honda Accord (involved in three car accident while pahked in the North End)
RIP 2002 Mini Cooper (90th produced)
Old 10-11-2012, 06:33 PM
Goes with the Flow
hmm ok thanks for the information . I haven't change it or reset it since Monday so I hope it has not effected the tires for 1 week off being improperly unbalance.
Old 10-11-2012, 06:41 PM
Goes with the Flow
ok so I check the manual but i don't understand my settings. I understand the front wheels is a complete different pressure then the back. I bought a pressure gauge , so I notice in the gauge it mentions KPa,PSI, BAR, now I'm in the states and my car is a BMW 2008xi Sedan , So can anyone help me out what number for what Kpa ,PSI,BAR should I be looking at ? What I'm understanding is that my front wheels have to be 32/220 (psi/kpa) and my rear wheels have to be 36/250. Is this correct , woud anybody? I would appreciate any information.
Old 10-11-2012, 06:42 PM
Goes with the Flow
So even after I set up the tired pressure correctly , the sign won't go away . I actually have to reset it ?
Old 10-11-2012, 06:50 PM
MMME30W MMME30W is offline
Mein Auto: .
Should be a sticker on the front driver door pillar with the tire pressure in either PSI or bar for your car.
Old 10-11-2012, 07:45 PM
pointandgo's Avatar
pointandgo pointandgo is online now
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
It's that time of year again!
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 10-11-2012, 08:16 PM
Hutchman Hutchman is offline
Mein Auto: 2011 328i, 01 325I
It just happened to mine a couple days ago as well. Filled up all the tires (right rear was the indicator). Light went out, no reset necessary.
Old 10-11-2012, 08:21 PM
Tom K. Tom K. is offline
With the tires cold, inflate each front tire to 32 psi and each rear tire to 36 psi.
Then look up "TPM - Resetting the System" in your owner's manual and follow the instructions to reset the TPMS.
Tom
Old 10-12-2012, 04:19 PM
Goes with the Flow
You are correct Good Sir , thanks for the info . It was so much easier then looking at the manual .
Old 10-12-2012, 04:20 PM
Goes with the Flow
I was so glad to see the light went out by it self after I filled the correct air pressure to each tire .
Goes with the Flow
Tom
Thanks for indicating the specific numbers , I appreciate it .
bmw 2008xi, tire pressure
