Old 10-09-2012, 08:30 PM
ill540i's Avatar
ill540i ill540i is offline
Mein Auto: Bmw 540i
540i low on coolant today?
I replaced my radiator about 8 months ago,including my upper hose and earlier i start my car and check coolant level comes up and i topped it of with water,i think i put a little too much,is it bad to drive it like that for about a month until i have enough founds to do the overhaul? And i also checked and can't see any leaks?
Sent from my MB502 using Bimmer App
Old 10-09-2012, 10:26 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
How much did you have to add?
If you really overfilled it just drain some out.
2000 540/6 Slightly tweeked...everywhere
Old 10-09-2012, 10:46 PM
ill540i's Avatar
Mein Auto: Bmw 540i
I really overfilled it the stick is coming all the way out=/
What would be the easiest way to drain some out?
Old 10-09-2012, 11:04 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Via the radiator drain valve.
Old 10-09-2012, 11:12 PM
ill540i's Avatar
Mein Auto: Bmw 540i
Do it while the car is on,or just has to be warmed up?
Old 10-10-2012, 07:25 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
or use a turkey baster to take coolant from
from overflow tank.
Old 10-10-2012, 07:43 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
Personally I use a turkey baster or something. I avoid pulling the radiator drain as it will let out quite a bit of water and is hard to control the flow/ get it back in. I probably go for the expansion tank bottom hose if not turkey baster. Do it when the engine is OFF and fully COLD, the same as testing the coolant level.
For the leak check under the expansion tank, where the sensor is. If you had a replacement expansion tank from Behr fitted, 8 months is bang on schedule for it to fail. You'll need to replace it with a genuine BMW one. Also check the metal/plastic joins on the radiator, these are a failure point even on new radiators. Otherwise it could be your valley pan gaskets, normally leak slowly and the water runs down the transmission area.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 10-10-2012, 07:49 PM
ill540i's Avatar
Mein Auto: Bmw 540i
I ve only had the radiator and the upper hose replaced,and thank you for the help guys im gonna reduce the water amount asap
