E90/E91/E92/E93 (2006 - 2013)
Old 09-26-2012, 08:11 PM
pastman pastman is offline
Mein Auto: 2007 328xi
BMW xi tire rotation
Hello Members:
What is the accepted tire rotation practice for the 328xi series?
Old 09-27-2012, 02:37 AM
///M-ratedE90's Avatar
///M-ratedE90 ///M-ratedE90 is offline
Ego writing cheques that
Mein Auto: Subaru Forester
BMW doesn't recommend rotating tires. If you search the forum, there are several discussions as to the pros and cons.
"To suffer the penalty of too much haste, which is too little speed." - Plato
Old 09-27-2012, 06:00 AM
rtgirard's Avatar
rtgirard rtgirard is offline
1-5-3-6-2-4
Send a message via Skype™ to rtgirard
Mein Auto: 2013 335xi
Originally Posted by pastman View Post
Hello Members:
BMW doesn't recommend rotation, but I do it anyway. As long as you have a square setup, I don't see any reason not to. Sure, some will say the negative camber in the rear will reduce grip until the recently-swapped tires wear in a bit, but for normal, everyday street driving (even including the occasional panic-stop) I don't think performance is affected to such a drastic degree.
I first rotated around 12k miles after noticing some ever-so-slight sawtoothing on the fronts. I've been rotating every 5k or so ever since without issue.
Aside from the longer treadlife, the next most important benefit is getting the wheels off once in a while to clean back there plus add a thin smear of anti-seize to keep the corrosion at bay.
F30 335xi - Ordered on 9/5/2012... Delivered 10/29/2012
Alpine|Coral|ZSL|ZPP|Nav|ZDH|SportAuto
BMWCCA# 457109
Old 09-27-2012, 07:51 AM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
The rotation pattern is dependent on the tires you have. The stock Turanzas my car came with were non directional, so the rotation was an X pattern. The Kuhmo summer tires were directional, so front to back.
I rotate every 5,000 miles or so. That has worked out well for me.
If you have a asymmetrical setup, don't bother rotating.
Also, although I think the BMW advice against rotating is ridiculous, I am not sure rotation buys much with an AWD vehicle.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Old 09-27-2012, 08:47 AM
Does anybody know BMW's rationale for not rotating tires? I run Nokian WR G2's year round (I live in Connecticut). I'm quite pleased with their performance in rain and even substaintial snow, and my days of driving more than 8/10ths in the dry are behind me. Any info would be greatly appreciated.
Old 09-28-2012, 05:55 PM
pointandgo's Avatar
pointandgo pointandgo is online now
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
BMW says that it's a safety problem and that you might die (not in so many words). In the meantime, Mercedes, Audi, VW, Germany's equivalent of the AAA all recommend tire rotation...not to mention every other car manufacturer in the world...and every tire manufacturer in the world. BMW marches to its own drum.
You should obey BMW! Suffer the noise that non-rotated tire's produce.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 09-28-2012, 08:48 PM
Thanks for the info, I think I will rotate them.
Old 09-29-2012, 06:56 AM
rtgirard's Avatar
1-5-3-6-2-4
Go for it. As long as you have a square setup and non-directional tread, a standard X pattern is totally fine.
BMWCCA# 457109
Old 09-29-2012, 07:52 AM
Actually, the Nokian WR G2's are assymetrical. My feeling is that the tires that steer the car are subjected to different wear than the tires in the rear of the car. I think that simple "front to back" rotation will be the way to go. Thanks for your input.
Old 09-29-2012, 10:45 AM
Chicks dig Wagons!
Mein Auto: E91
Asymmetrical means different size in back and front. You should not rotate under that circumstance.
You may mean directional, in which front to back is fine.
Old 10-11-2012, 07:08 AM
peripherique peripherique is offline
Mein Auto: 2009 328i XDrive Sedan
+1 go with the x pattern change.
Old 10-11-2012, 07:48 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi Sedan
That's "staggered." An asymmetrical tire has different tread patterns and/or compounds on its inboard and outboard edges. It doesn't affect the rotation pattern unless the tread is also directional.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
tire rotation service
