Old 01-10-2017, 04:58 AM
jason0 jason0 is offline
Mein Auto: x5
dashcam install with automatic windshield wipers
Am I correct to assume that I should not block the area directly in front of the rear-view mirror to prevent problems with the automatic windshield washers?
Is there specific instructions anywhere on what areas are required to be clear?
2012 X5
Old 01-10-2017, 05:04 AM
Ozer's Avatar
Ozer Ozer is offline
Mein Auto: 2011 X5 diesel
AutoWiper sensor is in that big bulky paner right behind the rear view mirror. If you look from outside you can see the sensor in there.
Only thing you may cover is the sensor for the auto dim on the rear view mirror but you can get away with it. I mounted mine right under the bulky cover vs right behind the mirror but i may move it when i run the permanent power cable to it.
Old 01-10-2017, 05:07 AM
Mein Auto: x5
I think we are using different direction terminology.. by "not block the area directly in front of the rear-view mirror" I meant towards the front of the car, windshield side of the rear-view mirror.
Old 01-10-2017, 08:40 AM
ard ard is online now
Resident Curmudgeon
It is not possible to block the rain sensor from INSIDE the car...
Old 01-10-2017, 08:42 AM
Mein Auto: x5
thanks... good to know
Old 01-10-2017, 09:49 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d - 06 325i
My dash cam is completely hidden behind my rear view mirror.
Old 01-10-2017, 04:27 PM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
If you have auto bright headlights option then the sensor is in back of rear view mirror. Don't block it, unless of course you've found the feature to be mostly useless as I did, given the fact it does not "see" headlights when traveling on a highway with a cement divider. I have it disabled.
