Old 10-10-2012, 03:26 PM
Sammyy90 Sammyy90 is offline
Mein Auto: 645 ci
Smoke from the back 645ci
Hey guys I have a 05 645, and if I'm stopped for more than a minute and then hit the gas I get massive amounts of smoke coming from the exhaust if I'm already driving and gas it hard it doesn't happen it's only when the car is stopped for a bit of time, no check engine light or any emergency errors have popped up on the screen, I'm afraid to take it to the dealer !! Any ideas of what's going on and how much I'm lookin at?
Old 10-10-2012, 04:28 PM
Skipraider Skipraider is offline
Mein Auto: BMW 650i
Maybe valve stem oil seals?
E63 650i
Old 10-10-2012, 04:59 PM
Mein Auto: 645 ci
Someone mentioned something about guide valve seals? Or gas valve... I have no idea anyway is that bad?!
Old 10-10-2012, 06:51 PM
HerbP HerbP is offline
Valve seals are probably the culprit's, but change the 2 CCV valves on the valve covers 1st. I think that they cost somewhere around 25.00 each, & will install in 15 to 30 minutes. You can do these yourself fairly easy. There is probably a DIY in the DIY section. If the valve seals are failing, replacement cost in around 3K. There is a lot of info on the 7 series forum concerning this problem.
Good Luck!
Old 10-10-2012, 07:28 PM
leewtech leewtech is offline
Gone for a drive.
Mein Auto: BMW, GM, Fountain
What color smoke? White? Black/Gray? Different issue for different color smoke.
Also are you hard accelerating when this happens?
Have you checked your coolant level/oil level lately? (again need to know color the smoke is) either of them down?
Old 10-11-2012, 05:43 AM
telecop38 telecop38 is offline
Mein Auto: 645Ci
I have the same problem...I moved my rear veiw mirror, can't see the rearview, it fix the problem; real cheap like
Old 10-11-2012, 08:36 AM
Mein Auto: 645 ci
LOL! Perfect solution !!!
Old 10-11-2012, 09:24 AM
Mein Auto: 645 ci
It's black/ grey smoke
Old 10-11-2012, 10:23 AM
Mein Auto: 645Ci
I love this car like crazy, I test drove all kinds of cars and can't find the one that will take me away from this madness, I LOVE MY CAR, it is in a class all by itself...I'm buying a 2010 650i convertible in January...It's $10,000 cheaper (winter time baby!!).
Old 10-11-2012, 10:24 AM
Mein Auto: 645 ci
I'm about to trade in for the new Mercedes cl550 if this smoke problem is a huge issue
Old 10-11-2012, 10:26 AM
Mein Auto: 645 ci
Cars are cheaper during the winter??
Old 10-11-2012, 10:40 AM
Mein Auto: 645Ci
Convertibles are...
Old 10-11-2012, 03:10 PM
Gone for a drive.
Could be oil burning or possibly engine dumping fuel into the motor at idle. Check your oil level. But need to take it to a pro for diagnosis at this point.
Old 10-11-2012, 03:58 PM
Mein Auto: 645 ci
Oil burning could make sense, my oil level is always low and I end up topping it off about once every 2 weeks
Old 10-11-2012, 04:17 PM
Gone for a drive.
that's pretty excessive oil use....
Old 10-11-2012, 04:20 PM
Mein Auto: 645 ci
So get rid of the car huh?
Old 10-11-2012, 06:10 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
If you are adding oil every 2 weeks then I would say you are having a seal issue. unfortunately you would have to have this checked to find out. Us here trying to diagnose your problem is not going to work for you. But we can be sure that it's an oil burning problem. Could be valve seal, head gasket, who knows. Don't give up on it until you get some feed back from a good indy shop.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 11-16-2012, 11:13 AM
Tourque Junkie Tourque Junkie is offline
Mein Auto: Acura TL
This is happening with my 4.4 X5 too. However, it only happens once in a while. Once or twice a week or so. My indy says valve seals. I don't understand why it is not more consistent. Have not obseved this on my 645 and it has 30K more miles.
