Old 10-10-2012, 01:32 PM
dmontalban dmontalban is offline
Mein Auto: bmw 325I 2002
Indicator and brake lamp are on
what could be the problem if the indicator lamp and brake lamp are on silmultaenously on my BMW 325i. Is it a quick fix?
I'd apprciate any feedback.
Thanks.
Old 10-10-2012, 01:42 PM
roverT's Avatar
roverT roverT is offline
Send a message via ICQ to roverT Send a message via AIM to roverT Send a message via MSN to roverT Send a message via Yahoo to roverT
Mein Auto: '04 ///M3 Individual
Indicator brake lamp?? I know most E46's have a separate indicator when brake pads are low. Usually it's an amber color. A red "brake" indicator is your parking brake lever which if it's down, then you have a fault switch. If it's amber along with an amber DSC, then the traction modules are not functioning. You'd have to give a more detailed description on what you see and what color it is.
--Trevor--
Vancouver, BC
Old 10-10-2012, 01:54 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Or post a pic of your gauge cluster
Old 10-11-2012, 04:58 AM
roverT,
The indicator lamp (triangle with an exclamation in it) and the light with the word "brake" are both on in color amber.
I believe this got to do with the DSC system.
Old 10-11-2012, 05:54 AM
smolck's Avatar
ROLL TIDE!
Originally Posted by dmontalban View Post
roverT,
You likely have a bad wheel speed sensor. The only way to tell which one for sure is to go to a shop that has a scanner that can tell you.
OR you accidentally held down your DSC button and turned it of. Push your DSC button and see if they go off.
