Old 10-11-2012, 05:59 PM
neilw neilw is offline
Mein Auto: 2010 535xi
FSU replaced, loose fit -- problem?
I replaced my faulty FSU unit . The blower now works just fine. However, The FSU is now a Slightly loose fit. My old hands are not nimble enough to push the unit Firmly in place. Is this a problem? It is in place, but I can rock it just a bit. It didn't snap into place firmly with Clip. It is the right part # based on realOEM for my 2003 530, and it is correctly aligned in general. I will be taking it on a road trip for a torque converter overhaul in a few weeks, but want to be sure I am not hurting anything in the meantime.
2003 530i
2010 535xi
Old 10-11-2012, 07:34 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
I feel ya, it's a PITA job.
Do the 2 holes on the FSU correctly get inserted into the "prongs" on the car? I had to fight getting it aligned for awhile.
Make sure you lower the release tab while inserting the FSU back in, you'll know it's fully in when the release tab is stopping the fsu from comming out and if you have darn good eye sight, can see that the two holes are fulled.
When correctly placed it the position will be like this (LINK)
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 10-11-2012, 07:37 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Since it's not seated, there will be air leakage, and possible improper operation. There may even be wind noise.
I suggest you get a neighbor teen the seat the FSU. The clip is strong.
Are you sure you have it properly oriented into the hole? It only snaps in one way, but is easy to install improperly.
Old 10-11-2012, 07:47 PM
I used your photos and text as part of my guide for this job. However, I could only actually see the FSU in a mirror. And I could only get a few fingers in there which blocked the view of coarse. As a senior citizen, it's not the easiest fit for me under the dash. Bit of a miricle I actually got the old one out.
I guess my real concern is whether it will be okay until I get to the major metro Indy shop in a couple weeks. I can then have a younger, more nimble person seat it for me. Don't want to cause issues, especially for the 500 mile road trip to the shop.
2003 530i
2010 535xi
Old 10-11-2012, 07:59 PM
I did a 200 mile commute to work yesterday after the repairs in cold, rainy weather and it seemed to work fine. Went from 70 degree weather needing a/c, to later that evening hitting 35 or so in rain. Heat and temp were fine. A/c seemed to work fine. Didn't seem to hear any wind noise difference. Just nervous that something else will fail.
I am hoping that as easy as it was to fix the blower, nothing is going to get screwed up because I can't get the FSU fully seated for awhile.
2003 530i
2010 535xi
