Old 10-10-2012, 04:31 PM
2625 2625 is offline
Mein Auto: X1
X1 28i 8speed auto accelarate hesitation
Anyone experience a slight delay in accelaration when step on the gas after a rolling stop? Is it normal for the 28i with 8 speed auto? It is my first car with turbo engine and wondering if there is anything to do with it. Or is it related to the transmisson? I just feel the car has no power for a second than give you a jerk and pick up speed. The delay is less obvious if i do a complete stop before stepping on the gas. Any thoughts? Thanks.
Old 10-10-2012, 04:40 PM
dong4ce dong4ce is offline
Mein Auto: X1
Might have something to do with the auto start/stop option?
Old 10-10-2012, 05:29 PM
Mein Auto: X1
Forget to mention mine is 2012 model and doesn't come with ASS.
Old 10-10-2012, 05:37 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
Still an issue huh....
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 10-10-2012, 06:35 PM
lovemygsp lovemygsp is offline
Mein Auto: 2013 X1
Do you have the ecopro mode and is it on?
Also thought of something else: Are you pushing the gas petal to the floor? If so this places it into kickdown mode and it could be taking a second to kick in. You would feel a little click type sensation in the petal where there is a "button" that activates it. ...Maybe its a bit of a stretch but it was an idea.
Otherwise I don't know. We haven't been pushing our 2013 at all yet as we are still in the break-in period but I only notice it having a slight hesitation when the ecopro mode is on.
Old 10-11-2012, 04:07 AM
Mein Auto: X1
Thanks but no ecopro as well. Rarely need to floor the gas pedal. I suspect it is related to the transmission...
Old 10-11-2012, 08:15 AM
CanadianDriver CanadianDriver is offline
Mein Auto: 2008 328xi
maybe try using your X1 on DS or even manual shifting for a day, just to remap the transmission memory
you may even end up liking manually shifting +/-, esp if you have flappy paddles =)
Old 10-11-2012, 10:25 AM
faustas faustas is offline
Mein Auto: Toyota
My experience with the 28i (2013, first US model) is that when I step on the gas pedal from a complete stop, there's a moment when the acceleration seemed very soft. It didn't seem to me to be a delay, but just really soft acceleration, for a short duration or until I press down the gas pedal more. (Not sure what mode I was driving on at the time :O)
Old 10-11-2012, 05:04 PM
Mein Auto: X1
Thanks CanadianDriver. I will try the manual shift for a couple of days to see if it will make any different. I've tried the DS while approaching the rolling stop. It made the car jerked even more. Too bad...don't have the happy padel shifters in my X1. I used to have them in my last Rogue but they were seldem used so opt not to have them. I guess it's better to have and not used them than need them and don't have. Only if I know then...
Sent from my LG-P925g using Bimmer App
Old 10-11-2012, 06:52 PM
HotRodW HotRodW is offline
Mein Auto: 2013 X1, 2012 Q5
Our Q5 2.0T with the same transmission also suffers from a throttle delay, although I find it to be a little more obtrusive in the Audi. I would describe the hesitation as "throttle lag" rather than "turbo lag", and while some of the lag may be transmission-related, the throttle-by-wire it likely a contributing factor as well.
Rod
2014 Touareg TDI R Line
2012 Q5 2.0T
2002 RSX
Old 10-12-2012, 04:34 PM
Mein Auto: X1
spoke to the service manager at bmw today, he agreed with CanadianDriver's suggestion. But also said I could take the vehicle back for them to have a check.
Old 10-18-2012, 07:01 AM
douggie douggie is offline
Mein Auto: 5
The new X3 suffers from this as well. This one is documented with accelerometers and GPS:
http://m.motortrend.com/roadtests/on...#ixzz1scygJTyj
Old 10-18-2012, 08:53 AM
edx1's Avatar
edx1 edx1 is offline
Missing German roads
Mein Auto: X1 xDrive35i,Z3 Coupe 3.0
I checked google and it appears many models using the 8spd trans has the same problem, and it's been known for about 2 years. Not sure if it's on purpose (ecu detecting a quirk and reacting) because you'd think BMW would address it by now.
Not sure if this would work on an X1 but it sounds like an ECU reset might help.
http://www.bmw-sg.com/forums/help-wh...-0-10-mph.html
For lots of other threads just google 'bmw 8 speed transmission hesitation'
Old 10-18-2012, 06:43 PM
Mein Auto: X1
Good information. Thanks. Not sure the reset will work on the e84 X1, but is there any risk of trying? Manual shifting does force it to start at the first gear and reduce the delay to a minimum.
Old 10-21-2012, 08:05 AM
kosmo kosmo is offline
Mein Auto: 128
You are describing the single biggest disappointment I experienced during test drives of the X1 (turbo 4, 8-spd) and X3 (NA 6, 8-spd). Since both engines exhibited it to the same degree, I concluded it was the new 8-spd transmission.
Bring on the 6-spd manual!
HotRod also makes a good point that some of this is due to throttle by wire, and specifically the emissions-related tuning incorporated into that system.
Old 10-23-2012, 06:25 PM
RV8Pilot RV8Pilot is offline
Mein Auto: M3
I have an '11 X5 Diesel with the six speed trans and have the same hesitation problem. When I complained to the service department the SA told me to move the shifter into sport mode and I've tried that without success. I think it's BMW's transmission programing that's the problem.
Old 10-23-2012, 08:28 PM
The 8-speed ZF transmission in the Q5 behaves the same way.
Rod
2012 Q5 2.0T
2002 RSX
