Old 10-11-2012, 10:14 AM
lovemyz3 lovemyz3 is offline
Mein Auto: Z3
Electric Side Mirror Acting Strange
So I have been meaning to fix this for years.
My passenger side electric side mirror points upward and when I use the electronic button inside the car, the mirror only goes up and pops and then keeps going up. (Mirror will not pan down). If I manually use my hand to push the mirror down, it will eventually float angling upward.
Any help with fixing this???
Old 10-15-2012, 05:39 PM
Mein Auto: Z3
Any ideas?
Old 10-16-2012, 04:51 AM
crappyattitude1 crappyattitude1 is offline
YYZED3M Driver
Mein Auto: '99 ////M Roadster
I have not had this issue myself.....
But it sounds as if you have a bad switch or the contacts on the adjustment motor are stuck.
Crappy : )
(Just outside of Nashville)
Old 11-01-2012, 09:39 AM
Mein Auto: Z3
Crappy : )
Yeah, its pretty bad. I am bumping this thread so maybe someone else has an idea. I am planning on taking it apart soon but would like a heads up on things to check.
Old 11-02-2012, 03:27 AM
Kornknarr Kornknarr is offline
Mein Auto: Z3 roadster
How to at least
This is at least a good thread on how to get to the motor etc. Its written for the M:s, and is about painting the mirrorbase but it has good shots on how to open up the mirror and what to expect. http://www.zroadster.net/forum/viewt...p?f=18&t=23387
It's also good cause it shows you don't need to open up the door card to be able to remove the mirrors.
Per
