Old 10-11-2012, 12:51 PM
7amadabmw 7amadabmw is offline
Mein Auto: Caddy
Another 2010 535xi issue.
So it's been getting cold (-1 c) in the morning, and the car is not liking it. The very first early morning start end up with a service engine light, revs below 500 rpm then hesitates and shuts off. I would have to turn it back on and rev it to 2000 rpm then drive off. But even as it drives off it feels very heavy.
Called BMW assist, since the closest dealer is 500 Kms away from me, and they were useless. Can't do anything for me till a week from now
Any ideas?
Old 10-11-2012, 01:56 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Is the gas tank full? Are you using 93 octane? Plugs and coils ok?
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 10-11-2012, 03:12 PM
CleanE60's Avatar
CleanE60 CleanE60 is offline
Mein Auto: 2010 535i xdrive
how many miles if you are under 50 they should tow it for you as well. you need a loaner too!
Keep it clean!
Old 10-11-2012, 10:28 PM
Mein Auto: Caddy
It has 20k miles. It's well within the warranty but their service is garbage. They are willing to tow the car there and get it fixed but they can't tow it back. I will have to pick it up. So I was hoping to take care of the issue without towing it there.
91 is the highest octane I can get here. I don't think the plugs have been changed before
Old 10-12-2012, 09:05 AM
Oceans10's Avatar
was just wondeing if condensation had gotten into the tank and fuel lines.
It sounds like a fuel delivery problem, so could also be the HPFP or injectors.
BMW will know as soon as they connect the car to a diagnostic computer, should show the fault codes.
Old 10-12-2012, 11:39 AM
CleanE60's Avatar
Canada sucks in that case dude. Damn well as long as they service and warranty the work that all that matters.
Keep it clean!
Old 10-12-2012, 11:59 AM
bighead2267 bighead2267 is offline
Mein Auto: E60 with a turbo
not sure where the OP from but Calgary Canada is one of the worse place to own BMW. both dealership services is worse than Kia. 200% piece of **** services. i try to avoid them as much as i could.
Old 10-12-2012, 03:50 PM
nickp3 nickp3 is offline
Mein Auto: 08 535i
A low/weak battery would cause weird symptoms. Have you gotten the battery checked out? Might be something simple like that.
Old 10-12-2012, 05:24 PM
Oceans10's Avatar
yeah, if the battery is over 4 years old then it might be time for a new one.
Doesn't fit the symptoms though, once the car is started up and running then the alternator is juicing the battery. It wouldn't start the car if it was too low on juice, so doesn't make sense.
But good to rule ut that issue.
Old 10-12-2012, 05:52 PM
CleanE60's Avatar
have you complained to corporate BMW about your experiences. did they do anything for u?
worse than kia is rough statement
Keep it clean!
Old 10-12-2012, 09:07 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
That's why I try to do my own service whenever possible. That said, I find if you're SPECIFIC in what you need done and don't take any guff from the service advisers you can get decent service for reasonable prices.
Old 10-12-2012, 10:57 PM
CleanE60's Avatar
So your telling me you can't buy a BMW in Canada because the service is such sh!t the car will inevitability fail?
Keep it clean!
Old 10-13-2012, 06:59 AM
Mein Auto: Caddy
I wish I was living in Calgary. At least you have 2 dealers near you. I life in fort Mcmurray man, the closest dealer is in Edmonton! So I called Edmonton BMW yesterday and the first thing the service manager asked was did I just move from Vancouver! Since I bought the car from Vancouver in July because it was 10k cheaper. I didn't even think about the consequences when I told him I just bought it from there, he told me there aren't any loaners available for me, nor can he get my car car in right away. It might be a week or so.
Old 10-13-2012, 07:13 AM
Mein Auto: Caddy
And another thing, they are willing to tow my car to Edmonton but once the car is fixed, I have to figure out a way to go get the car. They will not tow it back. Talk about unnecessary expenses.
Old 10-13-2012, 07:47 AM
BMWs since '87
Nothing so great about Calgary - both dealers are owned by the same people, so there's no competition between them.
I'd be looking at the plugs if it was mine, plus trying another gasoline vendor. And the comment about 93 octane being required: give me a break. 91 is plenty, but PetroCan has 94 at most places. Octane defines resistance to knock - any more than the engine needs is a waste of money as all grades have the same BTU/lb.
Good luck with your car.
Old 10-13-2012, 08:15 AM
Mein Auto: Caddy
Thanks audiophool. Both petrocanada and shell top off at 91. I have been using petro but will switch to shell.
As for the car, the service engine light no longer turns off when restarting the car and I think there's a new knocking noise coming from the engine that wasn't there before. It increases as I rev higher.
Old 10-16-2012, 08:49 AM
Mein Auto: Caddy
A quick update. A tow truck came from Edmonton to Fort Mcmurray just to tow the car back to Edmonton!
I called customer relations, apparently the option of towing the car back to me when it's fixed in not available in Canada, it's only in the states! So I will have to fly or rent a car and go to Edmonton to pick it up! But BMW is willing to reimburse me up to $100 back for my expenses, woopty do.
Old 10-16-2012, 08:55 AM
Oceans10's Avatar
You could make a TV reality show out of this. "Life on the Tundra."
Old 10-16-2012, 08:43 PM
Mein Auto: Caddy
Haha yeah really. The service manager wanted to make me feel better, told me he has a customer that lives on the border of Alaska and he still had to get the car himself!
Old 10-16-2012, 09:13 PM
BMWs since '87
Yeah, there could be igloos and dogsleds too.
Old 10-22-2012, 08:12 PM
Mein Auto: Caddy
So just to update you guys. The codes they found were 29CD, 29CE, 29 CF. misfire cyl 1,2,3.
They replaced 3 injectors and 6 spark plugs
