Old 10-11-2012, 09:39 PM
pilot093 pilot093 is offline
Mein Auto: 1992 325i sedan
springs
thinking of going lower but wanna go with spring/shocks setup instead of coilovers.
whats the lowest you know that springs can take you? 2/2.5 inches lower?
reason why no coilovers is i think springs/shocks would be more reliable/performance than coilovers. i need some opinions! thanks
Old 10-11-2012, 10:21 PM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
HR Sport Springs will be the lowest..
Old 10-11-2012, 10:28 PM
how about struts? tryina get a nice combo of springs/shocks to go lower and improving performance
Old 10-11-2012, 11:03 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
i have koni sport which are adjustable, i plan on buying H&R sport springs.
Bilstein sport are also great
check out tire rack
http://www.tirerack.com/suspension/S...0&autoModClar=
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 10-12-2012, 05:30 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
There are two different H&R sets, the Sport set lower it like 1.3 in the front and .75 in the rear, the Race set lower a little more..
The Eibach set lowers it like none... your saggy oem springs are lower than an Eibach set...
B+G is probably the BEST spring I have ever used on a car, never used them on a BMW though- THEY ARE THE LOWEST on an E39 at 1.6 Front 1.0 Rear for a non sport model.
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 10-12-2012, 02:00 PM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
Originally Posted by illesztE39 View Post
H&R sport springs.
This.
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
