E46 (1999 - 2006)
Old 10-12-2012, 06:30 AM
Bafana Nkosi Bafana Nkosi is offline
Mein Auto: BMW 318 E46
Bmw e46 1999-2000 rough idling
Please help! Iam driving a BMW E46 1999-2000 Model Automatic in the morning when you start the car the idling is just horrible as it fluctuates and once engine is hot then it becomes normal. It does this even when the car has used and parked for while for instance an hr and you have to wait until it stabilise before you hit the road.
Regards
Mina
Old 10-12-2012, 07:01 AM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
Could be a few issues if happening when cold. One is the Vanos unit. Do you hear rattling type noise in the front o the engine when this happens? If so, most likely a Vanos unit. If not, I would check the idle control valve.
Another common col misfire could be collapsed lifters, but you would hear ticking type noise.
Good Luck!
Old 10-12-2012, 07:48 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
How bad is it? It could be the mischievous SAP. Hate that thing!
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 10-12-2012, 04:04 PM
jdauria jdauria is offline
Mein Auto: E39 ///M5
Clean your MAF, check lower intake boot for crack/tear
Hook up your e46 to a code reader, and provide codes please
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 10-13-2012, 04:36 PM
jcjdavis1's Avatar
jcjdavis1 jcjdavis1 is offline
Mein Auto: E46 1999 323i auto
Hi. With the engine running take off the oil filler cap, if the rough idle is just the same you have a vacuum leak. I would change all your vacuum/breather hoses.
You will find all your hose in RealOEM, buy them from the dealer. Jim
http://www.realoem.com/bmw/partgrp.d...2&mospid=47631
The older I get the wrong bit gets stiff!!
