Old 10-12-2012, 10:00 AM
rocket98 rocket98 is offline
Mein Auto: 2000 740i
How do you reset the OBD codes
I went for an inspection on my 740i and the camshaft position sensor code came up. How can you reset the OBD with out the scanner. I have ordered the OEM part but I need to get thru inspection. I have heard that you can disconnect the battery and hold the terminals together for a couple minutes. Can I reset the codes and get thru inspection before they reset?
CAr information 2000 740i, M-62 build date 3/99
Old 10-12-2012, 12:47 PM
beemer1804's Avatar
beemer1804 beemer1804 is offline
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
I believe your e38 is obd2, you would need an scanner that resets also,thats the only way you can clear the code.
War Machine
Old 10-12-2012, 08:03 PM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Are you near Alamogor NM? I can reset for you.
Old 10-12-2012, 09:17 PM
Thanks for the offer
I'm in the east mountians outside of Albuquerque. I think I have someone to reset it for me. Do you have any idea how far you can drive before it scans the codes again. I just need to get thru inspection
Old 10-12-2012, 09:20 PM
BMWFatherFigure's Avatar
Old School
Usually about 3 miles will bring up all codes - some sooner.l
Current:
E38 Parts Car
Previous:
Old 10-12-2012, 11:48 PM
Thanks for the responce^^^
Old 10-16-2012, 12:16 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by rocket98 View Post
...Do you have any idea how far you can drive before it scans the codes again. I just need to get thru inspection
An OBD Drive Cycle may or may not be completed during a single driving event. The various areas of the emissions control system are "tested" during various/different conditions...so again, all may not be completed during a drive cycle.
Q {BMW CCA Member #191509}
(SOLD)
HTML code is Off
