E46 (1999 - 2006)
Old 10-12-2012, 11:28 AM
blackmagice46 blackmagice46 is offline
Mein Auto: BMW 318i E46
Bmw 318i e46 wont start help please
Hi everyone. iv recently purchased a BMW 318i E46 5 door. after a few weeks of driving it i noticed that it was leaking oil from the oil fillter housing, so i replaced the gasket and the oil filter etc... as you all probably know to get down to the gasket you have to remove the altinator/air filter atc. iv put all the parts back in reverse order and now the car wont start. the car has never had any starting problems before to my knowlage, only that some time the starter motor would stick on first turn but then it would be ok. any idea please people need it sorted asap thanks
Old 10-12-2012, 12:17 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Is the engine cranking over ? At normal speed ? When you turn the key to Position 2, do you hear the "whirring" noise of the fuel pump priming the system ?
Have you read the E46 Wiki ?
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 10-12-2012, 12:21 PM
no engine wont crank over, all that happens is i turn the key and it does a clicking sound. all electricals seam really slow and light dim!no i havent yet.
Old 10-12-2012, 12:27 PM
hexy27's Avatar
hexy27 hexy27 is offline
GO FLYERS!!!
Mein Auto: 2002 330i
Sounds like it could be as simple as a dead battery
Old 10-12-2012, 12:29 PM
Thats exactly what i thought but why would it just go like that after disconecting altinator and battery
Old 10-12-2012, 12:46 PM
Fast Bob's Avatar
Keeping it surreal
Batteries often die with little or no warning....happens all the time.
(R.I.P. Jever)
Old 10-12-2012, 01:36 PM
papalou13 papalou13 is offline
Mein Auto: BMW 325CI
Try to jump the battery or replace it, then you will know if your alternator drained it.
Old 10-12-2012, 02:43 PM
Thanks everyone for replying. i shall try and put some leads or a replacment battery in her tomorrow and let you know how it goes. once again thanks
Old 10-12-2012, 09:29 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
If not battery, then next consider a starter problem.
Old 10-12-2012, 10:47 PM
lgr122 lgr122 is offline
Mein Auto: BMW e46 1,9l M43
Which makes me think, that should actually check how old is my battery...
lots of things are still according how previous owner put them so i don't know for sure myself.
Old 10-15-2012, 07:42 AM
Put the battery on charge this morning and the car just started up. thanks for all your help lads.
OH and how do i add a profile picture on here so i can show off my car haaa
Old 10-15-2012, 08:16 AM
Pictures of your car can be added in "My Garage", or optionally going into your profile (click your name) and then add album.
Older members may correct me if i adviced bit wrong.
Old 10-15-2012, 01:42 PM
Anytime Lad
