E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#51
It was about 16-20" deep and 50 yards across. I am sure he hit the water going too fast and the wave came over the front getting sucked into the stock inlet at the top of the grill. There was a 5" thunderstorm downpour and we use the streets for drainage in west Texas.. when you see a river where a street was.. TURN AROUND |
#52
Thanks. I tend to avoid puddles but this is just simply amazing.
I'm also amazed that the engine appeared to run afterward, as one of those pistons is so bent I can't imagine it traveling up and down without supreme friction. Simply amazing. You're one of the FEW people here who can rebuild an engine. I'm impressed. That's why I tried to link this thread with as many relevant E39 threads as I could (same M54 engine). thanks.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#53
Not only did it run but it had good power. I was really surprised to find so much damage inside... These are great engines |
#54
Update
Should have my computer back from the programmer this week.. Eager to get it on the road!
#55
Good luck!
#56
It's alive!!
Received the module yesterday and everything works perfectly. I took the car out to run through the break in.. WOW, I forgot how smooth and even the torque is on the 330... break in can be a lot of fun
#57
Congratulations on a job well done. I hope that you have many happy miles and smiles.
#58
Congrats !
Glad to hear you`re back on the road !
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
#59
Awesome man!. Good work.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
#60
I read the entire thread and just congrats
)You did it. Fixing something makes someone feel much better than simply replacing it. Though I didn't understand how the stuck injector(s) burned up the DME ![]() Why did the injectors get stuck at first try and then they worked properly after you put in a new DME? Could you care to share a bit more info with us?
#61
Well done! I'm impressed.
![]() 07 650i and 02 330cic |
#62
I tested every part of the injector circuits twice before reinstalling the DME.. all is well now. I always disconnect and reconnect the battery as the first and last step of any remove/replace.. considered the possibility that it happened when he hit the water but it still ran ok.. may have just lost #5 then and it cooked the other 2 upon restart ![]() Thanks to all for the congrats, the most satisfying part of this project is the end result... a fresh engine in a sweeeet 330I 100% paid in full!
#63
Congrats
#64
Excellent! Having paid off vehicles is a very nice bonus.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!! U. S. M. C. Semper Fidelis
#65
Thought I should post up the pics..
#66
Nice looking car. Would have been shameful to crush it. Again, very impressed.
#67
I still have some work to do.. it seems the water killed my idle control valve as well. I have a new Bosch oem unit on the way. Also leaning toward new drilled rotors and ceramic pads... it could use them |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
