Old 11-12-2014, 06:32 PM
slongX5 slongX5 is offline
Mein Auto: X5
Cool Ignition Wire Harness Voltages/2000 528i
Hello all,
I own a 2000 528i, and the Ignition Wire Harness was recently cut in an attempted car theft. I believe this is the x33 cable. It has 6 wires running to it, and all 6 were cut. The wires are as follows:
Pin 2-Terminal 30-purple
Pin 3-Terminal 30-green
Pin 5-E voltage-red
Pin 6-E voltage supply-red
Pin 7-E voltage-red
Pin 8 -Signal DME-black
I soldered the wires back and attempted to start but I am not getting an power to dash, or start. I checked for voltages, and had about 6 to 7 volts across pins 2 and 3 and one of the reds(not sure which one.
I am not sure what the voltages should be at each key position, or prior to the key being placed in the ignition. Could someone please help me out as I am really needing to get my vehicle running.
Thanks in advance
Old 11-12-2014, 06:51 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
check your fuse's?
more then likely a bunch of things where shorted when the person cut thur the harness.. knowing that they didnt dissconnect the battery.. knowing they didnt cut one at a time,
GOod luck
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
Old 11-12-2014, 06:58 PM
Mein Auto: X5
Ignition Harness 2000 528i
Hi, Thanks for the quick reply.
I did check the ones in the glove box and the truck, but not sure how to get to the ones below the passenger seat. Would I have to move the seat to get to these fuses? I believe the red wire fuses are located there.
Old 11-12-2014, 08:13 PM
bartelbe's Avatar
bartelbe bartelbe is offline
Mein Auto: 2xe39,e34,e32,e36
Yes, remove the seat. Also there's a stack of fuses under the right hvac filter housing.
Old 11-13-2014, 06:03 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Under the air filter duct work on the passengers side of the car,,fuses and relays located there also.
Old 11-13-2014, 06:52 AM
rdl rdl is online now
Mein Auto: 530i 2003
See the attached schematic for your car
Nothing for pin 9?
6 or 7 volts from pins 2, 3 and a red is a bit unclear as to which to which. It could be a case of B+ from a red to fuses on pins 1 &/or 2 has just enough conduction through the voltmeter (which has very high resistance) that the voltage drop of the small current is shared between the voltmeter and the devices on the fuses. Or is the car battery is badly discharged?
A836 is the EWS module according to WDS, associated with but not the DME itself
You'll have to pull a fuse to identify which red 4 mm2 is which. Both F111 & F114 should be at B+ all the time, i.e. unswitched. F114 is easiest to get at - see the locator picture. EDIT: I should have mentioned - over battery behind a white plastic cover, mounted on the wheel well.
X10202 provides B+ to glovebox fuses F37 to F45 when switched.
X10176 has locator only, no schematic, but it connects to the glovebox fuse block too
Pin 9
F34 feeds the steering wheel heater - if fitted
F35 feeds rear compartment blower - if fitted
I doubt there is damage from shorts. Every wire in or out of the ignition switch is at B+ voltage at some times depending of key position. None of the wires are grounds.
Are you OK reading schematics? Post back if you need more help on a testing strategy.
EDIT2: Oops, not the schematic I intended. I've added the "with IHKA" version which includes F35
ID:	475792   Click image for larger version
ID:	475793   Click image for larger version
Regards
RDL
Old 11-13-2014, 07:58 PM
Mein Auto: X5
Cool Ignition harness/200 528i
Thanks RDI for the information. It will come in handy when I work on it this weekend. And, yes I am very good in reading schematic. Was in the electronics industry for years. Once I come up with a conclusion or a fix, I will post.
