Tailgate unlocks in reverse
I own a 2001 e39 wagon
I can't open my tailgate or the window without having to do it manually by pulling on the cord inside the hatch. Everytime i try to open it, it will unlock and move the tailage to where you have to open it manually, but then it will re-engage the actuator and lock again. Also, when i put the car in reverse, it will do the same thing. I've trying pulling on the tailgate while unlocking it, but it won't disengage fully, and it will re-lock again. Could this be a wiring issue in the hatch? I wonder this because my rear wiper and washer hasn't worked since owning the car, and i've taken a quick look to see that some wires are either on their way out or already broken in the upper part of the hatch. thanks Last edited by sullygullly; 01-22-2013 at 11:41 AM. |
The sedan has issues once the wires in the loom start to frey. Maybe the wagon has the same issues? One way to find out is to visually check.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
It does...and I'd definitely check once you can get the tail gate open. If memory is correct...I think you can open just the glass lift gate...look to the far right and you should see a loom that goes into the roof of the car. You may have to remove some of the small cover pieces on the right hinge to access the loom.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 01-22-2013 at 12:10 PM. |
