Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Parting Out
Parting Out
Old 10-14-2012, 01:31 AM
laferrari7 laferrari7 is offline
Mein Auto: m5
Parting out M5/M6 E60/E63 S85 engine
Parting out M5/M6 E60/E63 S85 engine with only 32k miles, let me know if you want pics of a specific part.
Cylinder head cover + profile Gasket ZYL. 1-5
Cylinder head cover + profile Gasket ZYL. 6-10
Control unit for ionic current
AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids
AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids
Vanos Oil line + connecting line
Vanos High-pressure pump + GEAR wheel + Sprocket
PRESSURE ACCUMULATOR ( bracket available )
TIMING CHAIN
Vanos gearbox, inlet
Vanos gearbox, outlet
Adjusting pulley with lever with Belt tensioner
Connecting rod
Connecting rod + piston and rings
set of piston Rings
Flywheel
Clutch
Vibration damper
INLET CAMSHAFT
CAMSHAFT EXHAUST
Camshaft sensor
Oil pump + suction pipe
Oil sump pump
Engine wiring harness
Actuator Idle control device
Fuel INJECTION TUBE + 10 fuel injectors
Throttle Housing Assy + Hall sensor
Thermostat housing + thermostat
Connector ZYL. 1-5
Connector ZYL. 6-10
I also have the cylinder heads.
I also have many hoses and lines, let me know what u need and Ill check.
ID:	345600   Click image for larger version
ID:	345601   Click image for larger version
ID:	345602   Click image for larger version
ID:	345603   Click image for larger version
Old 10-30-2012, 11:04 AM
Dark BMW Dark BMW is offline
Mein Auto: X5 4.4i--E46 325ci
I need an intake Manifold adjuster I believe the part number is 11617544805
It is the box on the manifold on the drivers side
Thank you
Old 10-30-2012, 11:25 AM
Mein Auto: m5
I can't find it with the part# u gave me. if you can find it on realoem.com, send me the part# so i can check if I have it. Thanks
Old 11-03-2012, 01:16 AM
Mein Auto: m5
bump
Old 11-08-2012, 09:52 AM
SammyM SammyM is offline
Mein Auto: 2000 BMW 540i
Mass Air Flow?
Old 11-09-2012, 06:04 PM
sr23det sr23det is offline
Mein Auto: bucket
you have the stock headers? how much for the set of 10 throttle bodys? price for each shipped to 94601
Old 11-09-2012, 07:26 PM
Mein Auto: m5
bump
Old 11-26-2012, 01:37 AM
Mein Auto: m5
ist of whats left:
TIMING CHAIN
Connecting rod
set of piston Rings
Flywheel
Clutch
Vibration damper
INLET CAMSHAFT
CAMSHAFT EXHAUST
Camshaft sensor
Connector ZYL. 1-5
Connector ZYL. 6-10
oil level sensor
I also have many hoses, vanos hoses and lines,
Old 02-01-2013, 05:15 PM
Mein Auto: m5
bump
