E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Hey everyone. So I bought a 2004 525i with 106k miles a couple months ago. However it has a trans issue I believe. In automatic mode, as I'm coming to a stop, I can actually feel the trans shifting into 1st gear.....RIGHT as a come to a stop. It's almost like I'm suddenly stomping the breaks if that makes sense. SO I started experimenting. At rest, I put the trans in Manual Mode, it automatically starts out at "MS" then you push the shifter forward to put it into 1st gear. When this is done, I can feel the car jolt forward as it shifts into 1st, and still at rest, I move the shifter backward to shift into 2nd, it jolts again. To me, it just feels like the transmission fluid a filter probably needs to be changed (I'll get into that in a second). I found the jolting to be weird so the experimenting continues....
I then take it for a drive in Manual Mode. There is no jolt what so ever as I shift through all the gears. It shifts normal according to what I think is normal. As I come to a stop, it automatically downshifts back down the gears, given I don't downshift myself, and as I come to a stop the trans stops down shifting at 2nd. To me, this doesn't sound right. Could anyone give me any insight on what it is i am experiencing? And what I can do to correct the issues. Now, on the trans oil/filter change. I've read numerous things on this forum in regards to doing a trans fluid/filter change. One, that it's fairly simple if you remotely know anything about maintenance on vehicles. And two, That (my car specifically) apparently has a "lifetime lubrication" transmission....And that changing the trans fluid/filter would be tranny suicide and will probably be FUBAR after it gets changed, and never be the same. I just find this hard to believe. So recap of questions that I need answers on: -Insight on the trans down shifting only down to 2nd? what am I feeling/experiencing? -What can I do (besides bring it to a stealer) to correct the problem? -Would it be okay for me to do the trans fluid/filter change myself? how long would it take? Thank you to all who reply! |
There's a huge thread on this, check the stickied threads in this section. There are a couple of issues--one is software related and can be updated, the other is something wrong with the mechatronics unit (valve body that is electronically controlled. usually it's the EGS solenoids that go out). Worst case, if the whole mechatronics has to be replaced, the parts are about $1500 from ZF. A BMW dealership will charge several times that for it, so don't let them rape you.
It's a software issue most likely so start there after fluid/filter change. Software can be updated by the dealer, or you could possibly do it yourself if you buy the right cables and learn to use the software. Yes you can do the fluid/filter change. It took me 2-3 hours to do it. The majority of that was just getting the car up on jack stands on all 4 corners, and getting the cover off (mine had one big cover that went from the front bumper to transmission). Pay attention to the fill procedure. https://www.thectsc.com/ has a kit with filter/fluid (filter is built into the pan so you have to replace the whole thing to replcae the filter). Personally I would only use ZF's transmission fluid. Others have found cheaper ones that seemed to have worked, but doesn't seem worth the risk to me to save a few bucks. http://forums.5series.net/diy-do-you...-refill-88129/ is a link to a write up on it. Unfortunately the pictures stopped working a week or two ago for some reason. Make sure you take out the fill plug before you drain any fluid out (don't want to drain the fluid then realize you can't put more back in..) Hopefully that helps! |
The software update fixed this for me.
2013 Scion FR-S 2007 550i Sport - GONE 2008 528i - GONE "What are you going to replace your BMW with?" "Another BMW, with a bigger engine!" |
BMW had to install a new tranny, They did software updates and all... Nothing fixed it, they replaced 2-3 parts before and it still didn't help. It's most likely a tranny issue. sorry man =(
It's all good. I'm not taking my car to a $tealer unless I absolutely have to. Pretty confident in my abilities. All I need tiger is the software, and a cable to upload it. I have a OBD Diag/Reset tool heading to me too. The $tealers can keep their tools.
If you need any help finding any of the software just let me know. |
Awesome! thanks brother. I may hit you up soon as I get the cable.
I hope you're more lucky than me, I wish the software update would have fixed the problem.
Well, if it turns out that I need a whole new tranny, ill just put up with it till it dies. It's really not a big issue at the monement. It's bareable. If I just drive in manual mode all the time, I don't even know te problem exists. It's more about just making the car as perfect as possible really at this point.
The 2-->1 issue has been fixed 99+% of the time by either software or a rebuilt mechatronics assembly. The problem is most dealers won't bother and just replace the whole transmission because that's what BMW says to do Last edited by schpenxel; 10-15-2012 at 01:49 PM. |
I didn't have to pay a dime, so i say "go right ahead, give me a tranny" lol
Well, in THAT case, BMW's "just replace the whole thing" policy works out great, lol
i kinda dont have that nice "replace anything for free" plan. I sort of purchased this car from a private party, and i'm pretty sure it no longer is under any kind of warranty. Sucks for me.....But in the same breath, Sucks for BMW that I can fix Sh**. Haha!
So I have found a few USB interface cables on Amazon. Any of these look familiar? Look like the right one that I need in order to upload the latest software?
![]() Let us know if you fix the problem. Goodluck!!! |
I'd just order the one from http://www.one-stop-electronics.com/shop/ and be done with it. It's been confirmed to work again and again.
If you google you can find people in the US that are getting rid of theirs, so that may save you some time (Wish I had went that route) |
That was actually a very helpful posted thread. So I think it's safe to say that I can do a trans oil/filter change, just as long the reset is done.
Consider a software update as well
Yes, absolutely. Just waiting on all the supplies to arrive. :-)
Me and you both, lol.
I finally broke down and just bought a used cable from someone on the forum. Should be here tomorrow. My new one is still stuck in customs somewhere |
This is probably one of the only times I hate living in Hawaii... Long shipping times, as well as outrageous shipping prices. Usually it costs just as much for shipping as the item I purchased..... Ugh!!!
http://www.one-stop-electronics.com/...&product_id=16 is the one most people around here prefer edit: after a very quick glance over the specs on that unit, I'm not sure it can really do anything useful for you in this situation. You need a cable you can connect to a computer. Last edited by schpenxel; 10-21-2012 at 03:44 PM. |
#25
Oh no.... I'm not using this to update the software for the trans issue. I'm still waiting on that cable. This was just to get rid of the check eng light, and reset the SRS fault.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
