E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
2004 330xi brake and rotor pad recommendations?
Thank you
Replace when worn... You are welcome
There`s already a couple thousand "What Brakes ?" threads archived here. Please use the SEARCH function for more info, or scroll backward through the older posts.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
1.) Most will say, If you have the cash stick with OEM. 2.) Cross drilled rotors are only beneficial for track use. 3.) My recommendation: The Value/Quality buy: Brembo rotors/Akebono Ceramic pads. Kit is sold through ECStuning.com. I have not had any problems with this set-up. Link: http://www.ecstuning.com/BMW-E46-330...g/Service_Kit/ Good luck with your research. Like our Moderator has already posted, If you have a question or seek a recommendation about your vehicle, there are usually countless others who have had the same problem or seek a similar qualified opinion. Search & Wiki = your friends Last edited by CLP-WGH; 10-14-2012 at 10:52 PM. |
Hawk HPS and any OEM replacement rotor from any of the countless online retailers (most of them sponsors).
Don't forget to order new wear sensors. Last edited by floydarogers; 10-15-2012 at 06:48 AM. Reason: wear sensors |
If the original sensors were never triggered, they really don`t need to be replaced....one thing you *should* have on hand is a few spare Allen-head screws that locate the rotors....they`re only about a buck each....
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
