Old 02-04-2013, 09:37 AM
lvly808 lvly808 is offline
Mein Auto: 745i
Not even a week and my car has problems!
I purchased a CPO 2010 535i xdrive about a week ago and this morning I go to run it and it has a rough start. Then I get the engine light and smoke coming out of the tail pipe. I filled the tank yesterday for the first time with 93. I am not sure what the heck is happening. I called the dealer and told them to come get the car. This is unacceptable for a CPO car that should have been inspected thoroughly. I hope it's nothing major. I feel like this is only a sign of more problems to come
Old 02-04-2013, 10:18 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
How cold was it this morning?
I have had this happen before and after it runs for a few minutes I've turned it off/restarted it and it was fine. Only happens when it's around freezing though.
I'm still not sure of the cause on mine.
Old 02-04-2013, 10:30 AM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
OP, could be fuel pump on its way out, bad coil/plugs, or some carbon buildup.....I'm sure the dealer will fix you right up!
2008 550i Sport-a.k.a. Hot Kraut Garbage
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR Sold
2005 Triumph Daytona 650 (wife) Sold
Old 02-04-2013, 11:02 AM
WilliCO's Avatar
WilliCO WilliCO is offline
1oz perception-1# obscure
Mein Auto: 2016 Chevrolet Tahoe
IMO, the "30 point inspection" (or whatever) part of the CPO value proposition is oversold. I think dealers look at age, mileage, visible condition, and make a subjective decision to CPO a car. So CPO doesn't guarantee a flawless car, it provides coverage for stuff that breaks.
-Will
2016 Chevrolet Tahoe LT | 2013 535i xDrive M-Sport (Retired) | 2005 545i Sport (Retired - best of the litter) | 2001 X5 3.0 Sport (Retired)
Old 02-04-2013, 11:29 AM
Cattani Cattani is offline
New to BMW
Mein Auto: 2006 550i
Dude, it is CPO. Whatever is wrong with it will be covered, so I wouldn't stress. These things happen. At least you got an issue early while it is still CPO, right?
2006 BMW 550i Base
Old 02-04-2013, 11:46 AM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
Welcome to the world of the N54 engine.
I am sure it will end up being the fuel injectors, but it could be the pressure regulators, low pressure fuel sensor, spark plugs, or hpfp.
I had to get all 6 fuel injectors replaced on my 2010 535i at about 32k miles because of rough idle at start. I now have 41k miles and all is well.
I believe the new injectors are an improved part.
What was you cars build date?
Old 02-04-2013, 11:48 AM
Also how many miles on your car?
Old 02-04-2013, 02:56 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
+1
I agree. I had the same issue 3 weeks ago and the dealer replaced all six injectors. Now my car starts up fine and the idle is smooth as silk.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 02-05-2013, 12:08 PM
Mein Auto: 745i
It was the fuel injector. They will only replace the one that has the problem. We asked them to replace them all and they said that they could only do that one that is broken. But with my warranty I should be ok if it happens again.
Old 02-05-2013, 12:09 PM
Mein Auto: 745i
Originally Posted by booyaazaa View Post
+1
I was hoping they would have replaced them all, but they only did the one that was causing problems.
Old 02-05-2013, 12:35 PM
vk535i vk535i is online now
Mein Auto: 535i
same me here!, I got my car (27k miles) first 3 days ran very smooth, after that it started shaking just like seating on the spa massage chair then 2 days later the check engine came on . I took to dealer and they found out the injectors were bad. (most common on BMW 5 series).
They have no parts available at the time. ( it was few days before x-mas). I ended up left my car at dealer after New year, They gave me a BMW loaner car. They replaced all the injectors. Now it's seem to be ok . sometimes I notice a little bit of fluctuate when in idle but after the engine gets hot then everything ok.
Keep the warranty and maybe extended warranty if needed will save you alot of head ache
Old 02-05-2013, 12:42 PM
Thats funny because I got my car with 27k miles too. The car was fine for a few days but then started to get rough at idle. It was a CPO car too, it makes me think the dealership knew about it before selling it but chose not to fix it.
Old 02-05-2013, 12:53 PM
Mein Auto: 535i
I do a lot research about this "rough idle" and found out there are many people have same problem with injectors (the common problem that dealer knows) they're not gonna replace it until the problem occur. What I read, with the new replacement injectors will imrove more and last longer. but who know (?) get warranty to keep peace in your mind
