E34 (1989 - 1995)
Old 10-15-2012, 06:45 AM
MikeyBabii MikeyBabii is offline
Car Crazy
Mein Auto: 92 BMW 525i
1992 525i Overheating issue!
Does anyone have any idea as to what reason my car is overheating? I can drive it for 15 minutes then it starts to overheat and I get a coolant temperature display. I think it might be the water pump since they are notorious for the plastic impeller failing but cant get the fan clutch off ... The hoses dont have any coolant running thru them when the car is on and pressure is high in the reservoir when overheated. Yes I am a FNG and all help is apreciated THANKS!!!
Old 10-15-2012, 07:26 AM
Banned
Mein Auto: car
1. Never pour cold water into an overheated engine. Let it cool down for at least 20 minutes.
2. Please read this thread slowly http://www.bimmerfest.com/forums/sho...d.php?t=651325
..it will answer most of your questions.
3. Please read this thread too http://www.bimmerboard.com/forums/posts/697674/
4. Try the stuff listed in both those threads thoroughly. Do not post back here until you've done so.
5. Repost here in your thread if you have further questions after having done what was suggested in both threads..
6. Please download and read through the bentley manual for E34s. There are troubleshooting sections there for overheat issues. Google for this download.
7. Stay calm. Its probably just the water pump and the thermostat. That's what it is most of the time. Good luck.
Old 10-17-2012, 09:39 PM
japbike736 japbike736 is online now
Mein Auto: 1993 525i
If robertobaggio20 says it you can count on it. He has helped me out several times.
Old 10-18-2012, 03:06 AM
BMWFatherFigure's Avatar
Old School
Fan clutch is LEFT HAND thread. 32mm spanner size. With tight fan belt fit spanner and hit it as though you are trying to tighten it. Worked for me every time.
Current:
E38 Parts Car
Previous:
Old 10-18-2012, 04:44 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
THIS^^^
In order to get the wrench into the tight space you can remove a couple of the water pump pulley bolts first, sounds like they will be coming out anyway.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 10-18-2012, 04:48 AM
The Ornery Old Man
Mein Auto: GTI
More Kool-Aid for you?
I don't see anything there a search wouldn't reveal... and "Don't post back until you have done so." Seriously?
Maybe better to stick with advice from folks who have actually done the work, not just read about it.
Old 10-18-2012, 08:15 PM
You take yourself to seriously my friend......Lighten up, it's a forum
