Old 10-16-2012, 08:40 AM
ayman ayman is offline
Mein Auto: bmw 740il & BMW M5 e39
BMW Welcome Light for E65 By dashsoft
Dear Friends,
as promised i have read the Full EPD File by DashSoft for DWA Modul which had already the Future of BMW Welcome Light.
Please download the Attached file from below link (make sure to press right click on the link and save as"
http://www.gulfbimmer.com/bimmerfest...929701_c03.epb
& follow the instruction:
Open Dashsoft (2.1)
Select DWA Module
Coding
FIRST THING YOU NEED TO DO IS BACKUP YOUR EPB FILE.
then press Load & Choose the attached EPD file
Press Write & ENJOY THE WELCOME LIGHT.
Very soon i will upload the file for One touch windows up & down. but i need to tested before that.
My regards,
ayman
Old 10-16-2012, 06:39 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Certified 7
Mein Auto: 2004 745i
I already have dash soft. What exactly does this coding do?
Old 10-16-2012, 06:51 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
Welcome lights - the park lights/headlights/fog lights illuminate when you hit the unlock on the FOB. I was told by a couple of members that you need a facelift light module for this to work.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-16-2012, 07:18 PM
wjjklj's Avatar
Certified 7
Mine does this when I hit the light button on my key fob. Not sure why I would want this programming.
Old 10-16-2012, 07:29 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
Originally Posted by ayman View Post
Dear Friends,
Please download the Attached file from below link (make sure to press right click in the link and save as"
Open Dashsoft (2.1)
Select DWA Module
Coding
then press Load & Choose the attached EPB file
My regards,
ayman
Sorry to inform you , but your method will do more harm then anything .
Not every 1 has the same LCM
So by doing things the way you suggest will not work for all & could possibly damage there LCM module .
Sent from my GT-I9100 using Bimmer App
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 10-16-2012, 10:56 PM
Dear Paper,
its not in LCM its in DWA Module
and all E65 Preface lift use the same HW Module C1. i have try the Worst to load different EDP file from another Module and Guess what its show me that this file is smaller then the original and cannot load it. so its SAFE. i already ask to do backup before load the new EPD file.
Old 10-16-2012, 11:51 PM
Tanny Tanny is offline
Mein Auto: BMW 735i
ayman, is it possible to set the welcome light so only the parker goes on?
Old 10-17-2012, 12:53 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Dear Paper,
Hmmm that's interesting . That your saying
its in the alarm system ( DWA )
I know when using NCS you must go into the LCM A.K.A LMA .
Sent from my GT-N7000 using Bimmer App
Old 10-17-2012, 01:15 AM
i think only E3X was the FOB light with the LCM, i have coded some E38 & e39 with BMW scanner 1.4 in LCM.
for e65 because they have the indicator Light with Beeb sound i think that's why they are in DWA module.
Old 10-17-2012, 05:36 AM
LMA is where I tried to code this feature and couldn't with NCS.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-18-2012, 07:32 AM
RON7165994 RON7165994 is offline
Mein Auto: 2004 745LI
Dear Friends,
Open Dashsoft (2.1)
Select DWA Module
Coding
My regards,
ayman
WHAT YEAR DO'S THIS WORK ON? I JUST DID IT ON MY 2004 745LI AND IT DIDN'T WORK
Old 10-18-2012, 08:08 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
You need to make sure you have a newer LMA .
I believe Stuart said it should be an LM2 .
ayman, bahrain, bmw, coding, e65, e66, gulfbimmer, welcome light
