Oil coming out of rear O2 sensor - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-16-2012, 09:38 AM
elmachin elmachin is offline
Mein Auto: 01 530i
Has anyone seen this before or know the cause of oil coming out of the rear O2 sensor.
It's a E46 99 328i
Thanks,
Matt
Old 10-16-2012, 10:23 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
It's a E46 99 328i
Thanks,
Matt
Something very bad would have to happen for that to take place. More likely your valve cover is leaking onto your exhaust and around the 02 sensor
Old 10-16-2012, 12:09 PM
Mein Auto: 01 530i
I don't think it's coming from the valve cover. Here's a picture.
https://docs.google.com/open?id=0Bz8...WJRbzFGX1kzYnM
Old 10-16-2012, 02:32 PM
smolck's Avatar
ROLL TIDE!
I cant see a picture, that link is bad.
Old 10-16-2012, 07:07 PM
BigJon53 BigJon53 is offline
Mein Auto: 2009 335i Coupe
It's a E46 99 328i
Thanks,
Matt
I can see the picture, but it is too bright in the area you are trying to show. I think Smolck is right, that is right in the area where you are going to see oil from the valve cover leaking. It falls on the manifold and burns off. The oil that falls on the O2 sensor just may not be burning off, so it only looks like it is leaking oil. If you really have oil coming from the O2 sensor, you have got way bigger problems.
Old 10-17-2012, 08:45 AM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Definitely the VCG, you can already see it on the heat shield.
Old 10-18-2012, 03:55 AM
gesoffen gesoffen is offline
Mein Auto: Rainbow Unicorn!
x3 on a leaky VCG (assuming the dark portions on the heat shield aren't underexposed areas of the picture). I'd recommend getting a replacement valve cover (includes perimeter and spark plug gasket) as well as the 15 sealing grommets for the bolts. Chances are you'll crack your existing valve cover if you replace just the gasket.
----Brian
Old 10-18-2012, 05:31 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Why would the vc crack when replacing the gasket? I would think chances are it won't crack unless you're just careless or don't properly torque the bolts.
Old 10-19-2012, 06:53 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
It's a E46 99 328i
Thanks,
Matt
Uhh if oil is commingle out of the 02 something horrible happens as stated above it is probably ly a leaking VCG takes 2 hours Max to do.
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 10-19-2012, 12:15 PM
smolck's Avatar
ROLL TIDE!
This. Clearly you can see the leak. No way the oil is coming from inside your manifold, it is an impossibility.
Old 11-15-2012, 07:25 AM
Mein Auto: 01 530i
gasket leak
I found a friend of a friend who works as a mechanic at a bmw dealership. He looked at it and said that it was in fact the gasket.
Thanks for your replies.
Old 11-15-2012, 06:35 PM
HarryR325i HarryR325i is offline
Mein Auto: 2002 BMW 325I
elmachin,
hold onto that friend.
o2 sensor oil leak
