Z4 Roadster (E85) Oddball engine issue - Bimmerfest - BMW Forums
Old 10-16-2012, 11:10 AM
meltonj72 meltonj72 is offline
Mein Auto: 2006 Z4 M
Question Oddball engine issue
I picked up a 2006 Z4 M back in May with 55k on it....definitely the best car I've owned, love the power, the steering, the suspension...all of it.
However, it's done something twice now that has me a bit spooked.
Basically, I'll be driving down the road, normal highway speed, and shift down to pass, etc, and I get a service engine light, and it starts running TERRIBLY. I mean, like no power, feels like three cylinders. Exhaust note goes punky, everything. First time it happened, I thought, oh crap, there goes my VANOS....so, I pull off the road, get out, listen to it, see if I've got disconnected plug wires, etc. Can't find anything, so I turn it of. A few minutes later, start it up, and presto, no issues at all.
Now, the first time this happened, I was at 12,000 feet on a road trip through the CO rockies....chalked it up to maybe some issue with the altitude and air/fuel mix.
But, same thing happened to me last night driving home from work...and just as before, I pulled off, turned it off, started it up, runs like a top.
I'm stumped....any thoughts?
Old 10-16-2012, 11:45 AM
flossy21 flossy21 is offline
Mein Auto: Ford Explorer
Water in the gas tank?
Has the weather/humidity been wet? maybe some water/condensation in the gas tank? Try dumping some "dry gas" in there.
Old 10-16-2012, 03:39 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
check for codes. gently tap on MAF sensoe with the car is idling....if it changes replace it. with it missing you should have at least a history code
Old 10-17-2012, 03:18 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Pull your codes. They will tell you what is going on. Good luck .
Old 10-26-2012, 02:04 PM
goeslikeschnell goeslikeschnell is offline
Mein Auto: 2006 Z4 3.0si roadster
agreed, pull the codes, I'd say it's likely the camshaft position sensor.
Old 10-26-2012, 04:45 PM
reddd reddd is offline
Mein Auto: Z4M Coupe
Check for loose vanos bolts. If they break it is bad news.
Old 10-27-2012, 05:56 AM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
The CEL is always emissions related. I'm going with the cam position sensor or possibly an O2 sensor.
drivetrain, electrical, engine
