Windshield washer not working, 2001 325xi - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-20-2012, 05:53 AM
unclewilbur unclewilbur is offline
Mein Auto: 2001 325xi, 1974 VW Bus
Good morning, and thank you for your help on this. I'm new here, and I have had my 325xi for a week now, so take it easy on the new guy please? I'm going to have some questions.
First one is this: I noticed that when I went to use the windshield washer yesterday, it doesn't work. The wipers come on, I know the fluid reservoir is full, but it doesn't come out. Where would I find the fuse on this, maybe it's the fuse? I'm assuming it's all connected.
Thanks for your help!
Old 10-20-2012, 08:19 AM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
You need a new windshield washer pump. Common failure. Very easy Diy (search forum). Literally takes 5 minutes and requires no tools. The part is 15 dollars or so.
Old 10-20-2012, 09:04 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
This
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 10-20-2012, 11:38 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
Could be bad electrical connection, missing tube or clogged line but, most likely the pump. One bolt, one electrical fitting. Make sure and replace the rubber gromet while you are there.
PT
___________________________________
Old 10-20-2012, 10:36 PM
Mein Auto: '04 330Ci 6-speed
Fuses happen too.
Fuses are in the glove box with a stiff paper diagram for fuse assignment. There are two thumbscrews in there to drop down the fuse panel.
Old 10-21-2012, 11:13 AM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
Originally Posted by GoForthFast View Post
Fuses happen too.
these fuses tend to blow when either the motor itself is bad, or the filter or the nozzles of windshield washers are clogged causing the motor to draw excessive current.
iATN
Old 10-22-2012, 06:43 AM
Thanks guys. I appreciate the input, and I will look at it probably this weekend when I get a chance.
