Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Performance
Performance
CAIs, SCs, differentials, SSKs, exhausts etc.....
Old 10-16-2012, 07:09 PM
330i ZHP 330i ZHP is offline
FORCED AIR FTW
Mein Auto: 05' BMW 330i ZHP and '04
JB Racing flywheel and Clutchmaster FX300 clutch
The setup has about 7000 miles of only a few runs at the track. Almost entirely street driven. Retail is around $1300 plus shipping - I will take $500 plus shipping - OBO
From the JB Racing website:
Fitment:
3/03 - 06 E46 325i, 330i w/ M54 2.5L, 3.0L - 6 cyl., 6-spd. only
Note: Above models equip w/ 6-speedZF manual transmission
Lightweight Aluminum flywheel replaces stock dual-mass flywheel. Accepts OEM clutch/pressure plate/throw-out bearing components as well as performance aftermarket direct replacements. Will also accept many aftermarket sprung-hub clutch discs. Provides improved throttle response and increased performance.
Note: Flywheel includes the hub mounted pilot bearing necessary for 6-speed transmission input shafts.
520-190-240 Clutch Diameter: 240mm OEM Flywheel Wt. 25.0 lbs.
List Price $722.50 Alum. Flywheel Wt. 10.5 lbs.
Order JBR p/n 520-190-240 Price: $595.00
From the ClutchMasters site:
Clutch or Flywheel Details
BMW > 330I > 3.0L E46 6 Speed > 03051-HDTZ-R
Stage: 3 > Years: 2003-2006 > Price: $895.00 >
(File photo for reference only.)
FX300 (Stage III)
· Heavy-duty street & racing system
· Holding capacity 110% over stock
· Heavy-Duty reinforced pressure plate
· Hi-Leverage™ pressure ring design
· Sprung hub/cushioned disc
· Steel backed Segmented Carbon/Kevlar
All Clutch Masters clutch kits come complete with:
Pressure Plate
Clutch Disc
Throw-out Bearing (when applicable)
Pilot Bearing or Bushing (when applicable)
- Stuart
Old 10-21-2012, 04:35 PM
^ECKS540i ^ECKS540i is offline
Mein Auto: 2000 540i6
Is that ONLY for 6cyl motors or do you believe it will fit on a 1999 E39 540i6. I'm looking for a lightweight flywheel myself.
Old 10-21-2012, 04:37 PM
FORCED AIR FTW
I do not know - but my hunch is that it only works with non M 6 cyl - but you could look up the part numbers on each site and verify
- Stuart
Old 11-02-2012, 08:28 PM
FORCED AIR FTW
bump
- Stuart
Old 11-04-2012, 09:47 PM
FORCED AIR FTW
Bump
- Stuart
