Z3 Roadster (E36/7) Replacing rear shock mounts. - Bimmerfest - BMW Forums
Old 10-18-2012, 10:57 PM
Z3ster Z3ster is offline
Mein Auto: Z3 3.0 2001 roadster
Hey,
I recently lowered my 2001 z3 3.0
& after a while I started hearing a thumping noise. I read a few post that suggest replacing my rear shock mounts for heavy duty ones. I was wondering if I should also replace the front mounts or do those usually hold up.
Thanks.
Old 10-19-2012, 05:52 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
They hold up, the rear ones are the weak ones.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-19-2012, 08:17 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Not exactly the shock mounts, but I have seen pictures of the Z3 front shock tower failing around the bolt holes. This seems to happen to cars that have been lowered to the point where they bottom-out frequently. It's not a problem for most set-ups. Reinforcement plates are available such as these:
http://www.turnermotorsport.com/p-19...ates-pair.aspx
Old 10-19-2012, 08:48 AM
babyZ babyZ is offline
Enthusiast
Mein Auto: 1997 BMW Z3
Had the same problem when I first got the Z. Bushings were rotted and jacked. Bolts were loose and stripped. It was a mess. Sounded like I was driving on cobblestones all the time.
Bought new billet mounts from Turner Motorsport.
Install is super easy. Also found that my rear shocks could be fully depressed by hand.
That was a terrible find. Replaced them and went ahead and installed the eccentric bolt camber kit. Fairly good results.
As just a suggestion, if you have the original shocks you might want to replace them when you do the install for saftey.
Good Luck!
Old 10-20-2012, 02:25 PM
Thanks for all the information !!
It's really helpful. I placed an order in for the heavy duty rear shock mounts & I'll go from there.
