Old 10-17-2012, 06:36 PM
tchavera tchavera is offline
Mein Auto: 323is
CVV Replacement help!
Hey guys just getting prepped to do some work. When you replaced your CVV did you have to remove the intake manifold to do all the hoses. I know a lot of people just replace to valve and don't have to take off the manifold. I'm going to do the hoses as well. Will I expect to take out the mani for the hoses?
Much appreciate!!
Old 10-17-2012, 07:07 PM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
You don have to remove the manifold, but having done it both ways, I find it much less frustrating to remove the manifold. If everything goes perfectly, it will be faster to do it with the manifold in situ, but i don't know of anyone that has actually not struggled mightily to reconnect the hoses.
Old 10-17-2012, 08:00 PM
Mein Auto: 323is
about how long to remove the mani?
Old 10-17-2012, 10:06 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
my indy removed the manifold when he did mine.
Old 10-17-2012, 10:12 PM
noego noego is online now
Mein Auto: '06 X3, 1997 Chevy truck,
here's part 1 of 3 from BavarianAuto
Old 10-18-2012, 05:20 AM
TA
If you are doing it for the first time, figure on 2 hrs to remove & 2 hrs to reinstall. Once you remove the strut brace, air intake, cabin filter housing & the ebox housing, everything is pretty accessible.
Old 10-18-2012, 06:36 AM
Dominic49's Avatar
Dominic49 Dominic49 is offline
Mein Auto: Bmw
if your oil filter housing is leaking now would be the time to replace it as with the housing removed the valve replacement is very simple.
Old 10-20-2012, 01:04 PM
bmwbob89 bmwbob89 is offline
Mein Auto: 2004 X-3 740i 325xi 88M5
Don't take the intake off. Makes it way to difficult and opens you up to more issues. Removed the alt and you will have plenty of room to work. I've done a couple this way and it really makes it easier. Like the above person said, if you have not replaced the oil filter housing gasket do it while your in there and makes life much easier. Make sure you use the winter version parts and the updated oil dipstick tube.
11 43 7 565 438 Dip Stick Guide Tube
Make sure you get an o ring for the guide tube.
Old 12-01-2012, 02:14 PM
buford buford is offline
Mein Auto: 2004 X3
Why is the oil tube replaced?
Old 12-01-2012, 03:34 PM
They updated it so it doesn't freeze shut with sludge and destroy your engine.
Moisture accumulating in the engine oil separator; hose to oil dipstick guide tube; or the orifice in the dipstick guide
tube can freeze. When this occurs, depending on the position of the internal valve, it may either cause high crankcase
pressures (stuck closed) resulting in valve cover leakage and/or breakage, or cause an oil hydro-lock condition (stuck
open), which could result in engine damage.
If the vehicle is not equipped with the new insulated crankcase ventilation valve and hose, replace those parts
with the updated style and replace the dipstick guide tube with the part number from the list by model below.
SI B 11 08 03
Engine
