Old 10-18-2012, 12:12 AM
leinine leinine is offline
Mein Auto: 535Li
Coding to enable voice recognition in 535Li
Hi All,
I am from China, and my car is 2011 F10 535Li. The voice recognition is not enabled by default. So I tried coding using E-sys by changing the following parameter:
CMB_MEDIA SVS_EIN_AUS: changing from nicht_aktiv00 to aktiv01
and now I can dial phone numbers/names using voice.
However, voice recognition for dialing is the ONLY function activated --- I could not use voice input for menu commands, such as Map, Radio, etc.
Does anyone help with this issue? What component/parameters I should code to fully enable voice recognition?
Thanks a lot in advance!
Old 10-29-2012, 06:15 PM
Nison Nison is offline
Mein Auto: 2011 535i xdrive
you need a FSC code from a dealer to enable voice recognition aka. voice control
