E30 (1982 - 1993)
Old 10-18-2012, 11:31 AM
musket musket is offline
Mein Auto: 1986 325
anti-lock brake light on
After fixing a broken wire on the anti-lock brake sensor. I don't know who to reset the the anti-lock light on dash back to a normal state. I have a 1986 325 base BMW could or would someone be able to help me. Is their a special tool I need to purchase. Just to reset a oil light cost me 85.00 dollars. Help me please.
Old 10-18-2012, 01:22 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Wow you got screwed on the oil light. http://www.noren.com/bmw/e30reset.htm
I do mine with a paper clip.
As for the ABS light you could always disconnect your battery, hold down the brake pedal down for a minute to discharge all energy from the system. Then connect it back up.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-18-2012, 01:46 PM
Mein Auto: 1986 325
Thanks for your reply. I just hate resetting the radio but will give it a shot. Plus for resetting the oil light on dash. How did you do it with a paper clip.?
Old 10-18-2012, 02:04 PM
Mein Auto: 1986 325
I am sorry to tell you, Your advice didn't work at all. their must be a special tool with a code to put in!
Old 10-18-2012, 04:26 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Make sure all 4 wheel sensors are good and no frayed wires. MAybe even take each one out and clean all the metal bits stuck on the magnets. If all the wires are good and the sensors look ok and you STILL have a light pull down the knee panel over the pedals and look at the silver control unit and there will be a silver relay clipped on top. Take relay out and verify the wrap around wire is intact. if not take a single strand of some decent gauge wire and resolder a new strand in.
If you still have a light then I have step 3, only a last resort.
Old 10-18-2012, 04:49 PM
Mein Auto: 1986 325
Thanks for your inform. Getting dark here now and I don't have a lift in my garage. But I will do it tomorrow. Newman 271 has a diagram which looks good to reset light on dash. I will do what you suggest first. Thanks Swiss! Hope to text back successful friend!
Old 10-19-2012, 06:51 AM
Newman271's Avatar
That Guy
My car thankfully doesn't have ABS lol. I only know this works from me owning close to 25 other cars through my 10 years of driving ha.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-21-2012, 05:15 AM
On Top
Well it doesn't work on e30's bro, the ABS control unit resets itself every time you start the car and soon as you start rolling if it detects a break/variance in the signal it triggers the light.
Old 10-22-2012, 01:26 PM
Newman271's Avatar
That Guy
what I meant was that on any of the other cars that I've had ABS issues with, it works. My advice to this guy is to take the bulb out of the ABS light and learn to brake fast without it. Normally if all the sensors have been replaced then the next options for problems dramatically jump up in price.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-23-2012, 02:58 AM
On Top
Relays are pricey?
If you think so I told you how to repair the relay, then the abs will work.
So your ABS fix is to take out the bulb.....
How would you fix SS?
Old 10-23-2012, 06:46 AM
Newman271's Avatar
That Guy
If its a relay problem.. could be the abs module or pump. Could even be something as stupid as a proportioning valve or something along those lines. Again I haven't messed with the ABS on a e30 so I can't say for sure but in my experiences it never as a easy as changing a relay. But hopefully it is for this guy.
As for SS, im assuming social security, I would bump the age to 68 for any one under 60 now. After that, I would set it up so every 10 years the age automatically increases 1 year to account for the over aging population living too long.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
