Old 10-18-2012, 08:02 PM
jackmo jackmo is offline
Mein Auto: 2003 540i M sport
540i Fuel Tank Vent Valve
How difficult is it to replace the Fuel Tank Vent Valve on 540i?
Old 10-18-2012, 08:21 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Are you referring to the DM-TL? If so, it's behind the left rear fender liner.
Old 10-18-2012, 08:29 PM
540i Fuel Vent Valve
Not the DM-TL, Vent Valve is supposed to be located between the Charcoal Canister and Throttle Body.
Old 10-18-2012, 09:46 PM
If you know where it is, it s/b easy to replace.
Old 10-18-2012, 10:40 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Very easy to replace! My tip is to get a U type tool that can be used to get the hose off, i had to really struggle with A flat screw drive, even using the old valve for leverage was hard, the hose is on there good, even when you take off the clamp. Then after frustration, i took my U shaped panel removal tool and presto, hose came off in seconds. Tip, replace the hose clamp on the hose you need to pull off, it's a very odd style clamp and i didnt like how it was a pita to compress/release so i replaced with a normal one.
Last tip, do it when the car is cold.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 10-19-2012, 07:08 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
It's located in the front of the drivers side head under the hood.
2000 540/6 Slightly tweeked...everywhere
Old 10-19-2012, 08:01 AM
PAULIN540I PAULIN540I is offline
540i stept bld date 6-02
Mein Auto: 2012SRX--2002 540i Steptr
Very easy---the plastic clamp to release the valve is a bit tricky--the first time you do it.
It presses INWARD to release the valve---but if you take off the 2 hose clamps you
bypass this procedure.
15 minute job--the first time---make sure you look at the flow direction--as I recall it is possible to put it on Backwards.
There was thread recently on where to order it---A BMW dealer in Md or Va.
On line it was a lot less expensive than going to the dealer.
Sorry, I threw away my paperwork when I sold the car 2 months ago.
2002 540I SPORT/STEPTRONIC
TITANIUM SILVER/BLACK 6-2002
Old 10-19-2012, 08:05 AM
I just pulled up my old post about the vent valve--should be right above this post
Old 10-19-2012, 07:56 PM
540i fuel Tank Vent Valve
Thanks to all for the assistance!! I will give it a shot.
