Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series
5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here.
Old 07-04-2004, 03:13 PM
Rush Rush is offline
Mein Auto: '98 540i6
Will e39 M5 clutch work on e39 540?
Will e39 M5 clutch work on e39 540? Thx
Rush
Old 07-05-2004, 06:02 AM
Lscman Lscman is offline
Mein Auto: 540i 6spd
I think so. I tried...I can not dig up any compatibility issues.
There is a slim change you'd need to convert to M5 slave cylinder for proper pedal feel & auto-adjust function, but I doubt it. In any case, this change can easily be done after the clutch is installed.
A 540i flywheel must be retained for crank positioning sensor function.
A slipping clutch invariably needs a new $600 flywheel.
You would be wise to consider a UUC clutch upgrade.
Engine rear main seals go around the 70K mi mark. Better add it to your shopping cart.
