Google's "Send to Car" - Bimmerfest - BMW Forums
Old 10-19-2012, 07:58 AM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Does anyone else find Google’s “Send to Car” to be very slow and delayed? Even if I send an address to my car the night before, when I get in the car in the morning there are times it does not receive a message until 30+ minutes after I start my car(!?), which is USELESS when you are in a rush in the morning, and I end up entering the address in manually. How do I speed this up!? It's not always consistent; sometimes works just ok, sometimes doesn't.
Old 10-19-2012, 08:40 AM
MCChuck's Avatar
MCChuck MCChuck is offline
Mein Auto: 2009 750Li
Luckily,my car usually takes a minute or two for the message to show up. Doesn't matter if car is on or off.
Old 10-19-2012, 10:37 AM
oneofew oneofew is offline
Mein Auto: 2011 B7 Alpina
My experience, and i use it pretty often, sends it within 30sec, not even a whole minute.
Old 10-19-2012, 01:04 PM
Thanks for your replies!
I don't park in my garage, but in my driveway. I also have great cell signal in and around my home.
It's never taken seconds after starting the car; it usually takes 3-5 minutes, and even 5 minutes is a lot when in a rush!
Unfortunately, I've run into the 30+ minute ordeal more than 5 times now; I've used the feature maybe 20 times over the past 2 years.
Watch the dealer claim they've never heard of the problem and that 5 minutes is 'normal' or that the problem is with Google, not BMW.
Old 10-19-2012, 01:14 PM
And, is there any way to easily send this from our iPhones?
Old 10-19-2012, 02:15 PM
06Black550i's Avatar
06Black550i 06Black550i is offline
Mein Auto: '12 Active Hybrid 7
Yes. You want the free BMW app
Old 10-19-2012, 02:23 PM
Not sure if this is you problem, but I use the original version BMW app that was released back in the day for on European i tunes. When i switched to the later version which was on US iTunes sent to car didn't function
Also have tested to see how long it takes for lock, honk, flash the lights function to react. It should not be any longer then a minute.
Old 10-19-2012, 02:57 PM
Fast. Thirty secs max
Old 10-19-2012, 04:54 PM
Hmm... Just downloaded BMW Remote; know my BMW Assist Username, which I suspect is the same as what I put into the Google Maps "Send to Car" page, but I can't recall my password. Does anyone know how to obtain / reset same? Thanks!
Old 10-20-2012, 12:58 PM
Call BMW asst and user name must be all caps for BMW remote app to let you log in
Old 10-20-2012, 12:59 PM
Thanks; got it working!
Old 10-20-2012, 10:16 PM
How long should it take to locate my car (engine off, doors locked)?
It’s taking my phone a very long time (5-10 minutes).
Old 10-21-2012, 07:41 AM
Make sure you hit the update button to the right of Vehicle Position -- that locates and sends signal to your phone. then hit the locator icon lower left
Old 10-21-2012, 08:07 AM
Thank you, yes, that's what I do. It says "data transfer successful" very quickly, but when I go to locate the car by pressing the lower left button (on the right) it takes forever…
