Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 10-19-2012, 10:31 AM
leedelta13 leedelta13 is offline
Mein Auto: 1996 750il
new owner help with my 1996 750il Radio does not work and starter problems!!
Hello everyone,
I have just brought my !st BMW and i am excited! I need a bit of guidance with a few issues though.
Radio does'nt work!
starter needs to be replaced!
#1 Radio. well sound comes thru the speakers when i turn the key and also when i push buttons on the phone. I can even hear some type of sound when i push other buttons on the stereo, but no radio stations, or Cd playing either. I checked the CD changer in the trunk and it seems to be working fine to me. please help!
#2. When I brought the car yesterday the person said to me that the starter needed to be replaced, I was and, am a bit unsure if he is correct because he didn't seem to know much about the car. I knew more than he did and i did not even own the car! is it possible that the starter is not the problem? maybe a fuse,relay,something of that type? when the key is inserted everything powers up fully. When the key is turned completely at times i hear clicking and when i do it again there is no sound. Any help would be greatly appreciated
yours truly Loving this car!!
Edit/Delete Message
Old 10-19-2012, 03:10 PM
First740i First740i is offline
Mein Auto: 740i
You first need to make sure you have a good battery. If the person you got the car from didn't know much, there is a good chance that battery is no good.
Sent from my DROID4 using Bimmer App
Old 10-20-2012, 04:59 AM
BMWFatherFigure's Avatar
Old School
+1 - Bad battery causes all sorts of problems. If still no good do the ign switch clean trick.
Current:
Previous:
Old 10-20-2012, 11:46 AM
Car will not start and radio will not start!
Hello Everyone!
Thanks for the replies!
I just came in from with a new battery. Still same problem. Good power. No start! Please keep the advice and insight coming. Thanks
Old 11-19-2012, 10:03 AM
Bm24 Bm24 is offline
Mein Auto: 1998 740iL
click sound when turning the key, but not all the time
hi, did you get htis resolved? i have similar issue where at times (maybe 20%) i turn the key, i hear a click, then nothing happens. re-turn the key and the car starts. any thoughts?
Old 11-19-2012, 03:39 PM
Working on the issue now
Hello and thanks for the reply.
I am currently in the process of changing the starter in my car then i hope the problem will be resolved.
I just brought my car. and it doesn't start but it does power up when the battery is attached. then after some time the battery begins to die. that's all i have right now.
I will post how the starter replacement goes. I hope i will be completed tomorrow.
Old 11-19-2012, 11:56 PM
Old School
CLEAN THE IGNITION SWITCH CONTACTS (off the car). It's a cheap fix (if it turns out to be wrong) and causes heaps of problems.
Current:
Previous:
Old 01-07-2013, 08:07 PM
Smile Iggy Switch Cleaning?
Hello everyone,
I have a a few developments!
First how do i clean the iggy switch??
thanks!
Old 01-08-2013, 01:26 PM
edognight edognight is offline
Mein Auto: 1997 e38. schwartzx2
ignition switch
there is a very informative post about it, and the guy took pictures, basically you take it apart and sand down the contact points, just like an old distributor. It is supposed to work pretty well, sorry, but I don't remember where the post is.
Also, he says in there 'do not take this apart, and listen cause it is an ordeal to get the plastic cam piece back together. I messed it up, hopefully you wont.
Old 01-11-2013, 08:13 PM
Update to everyone. I have had no development yet. to BM24 I have not had that problem. but to me i would clean the contacts as mentioned above. If you find or have found the post about the contact cleaning please send it to me. Thanks!
Old 01-12-2013, 01:41 PM
Hello everyone! Does anyone know how to clean the iggy contact.
My car it cranks but will not fire up.
1
How do i check the crank position sensor?
2
i have no power going to my obd. any suggestions?
3
What is a vanos?
4
There appears to be no broken CPS or wires
5
Where can i get a free bentley manual?
I really like this car and i am committed to getting my car started. Any help you provide i will greatly appreciate.
please help me!
Old 01-13-2013, 08:41 AM
Old School
I saw the ign switch post on a Dutch site - try google E38 problems. That is how I found it.
Current:
Previous:
HTML code is Off
