6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
Value of low mile rear run flats
My car has old front run flats with 46k miles and newish rear run flats with only about 7-10k miles (tires were replaced sometime after 1/12 by po.
Anyone know what they are worth? |
probably around half of the new price to a local buyer (also depends on the manufacture date, which can be found on the sidewall). research the new price on www.tirerack.com and go from there. good luck.
Regards, Greg '07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs '11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Miles is not a good gauge of tire life, you need to give tread depth for inside and outside edges. Since the 6 wear the inside edge faster it is the most critical. Once you know how much tread is left you can tell worth, 30% of tread depth is worth 30% of original value, maybe a bit less since someone will have to go through the hassle of mounting a tire and such, it has to have enough life left to make it worth it.
Will measure
You could probably check out EBAY for a good comparable price.
