Old 10-22-2012, 03:50 AM
tonykite tonykite is offline
Mein Auto: BMW E46 323i
Question 1999 E46 323i Auto Transmission
Hi looking for help, I had a rebuilt transmission and torque converter installed 18mths ago all was fine until I took it to the local BMW to get the ABS and SRS warning lights fixed along with a full service, they also updated the software. Since then the car has started going into limp mode with the following fault codes
049 Symptom gear chech
054 Gear check 4
048 Torque converter clutch too much slip
053 Gear check 3
Old 10-22-2012, 08:29 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
I would start by getting under the car and checking for damaged wiring or a disrupted electrical connector on the transmission or wiring harness leading to it.
Old 10-23-2012, 01:19 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
Sounds like something went wrong on the flash they did. I would suspect they coded it for the wrong trans as a blind guess.
Old 10-23-2012, 02:52 AM
Smile
Thanks guys will keep you informed
