Old 11-20-2012, 03:00 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Ive priced mine up to be around 1200 in parts and machine shop costs.
That includes:
All upper and lower timing case gaskets
Full set of upgraded timing chain guides (design revised to stop 'ticking' noise at idle)
Both head gaskets
Set of cylinder head bolts
Set of valve stem seals (To fix smoking at idle)
OEM coolant pipe and o-rings to fix inevitable weep hole leak! (for another 100k at least ha ha)
Full set of rocker cover gaskets
Front crankshaft oil seal
Crankshaft bolt
O-rings for VANOS solenoids
O-rings for vacuum pump
Exhaust manifold gasket set
Inlet manifold gasket set
Machine shop work includes:
Surface grinding of both cylinder heads by -0.3mm
Re-facing 32 valves
Re-cutting 32 valve seats
Leak testing
I will be doing all the labour myself, its a big job, I can see why the dealer charges so much!
+1 on the oil pressure switch leaking! mine went too!
Stuart
Old 11-20-2012, 03:05 PM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
That includes:
Both head gaskets
Crankshaft bolt
Re-facing 32 valves
Leak testing
Stuart
Stuart if you exchange that to dollars it would be near enough $2000 give or take
Sent from my GT-N7100 using Bimmer App
Old 12-04-2012, 12:37 PM
chp10_8 chp10_8 is offline
Mein Auto: A Quarter till 8
I'm coming up vacation days soon, id be willing to gather my tools and take a trip out there for you and correct all your issues shouldn't take more then 3-4 days. And it wouldn't run 7k
Old 09-19-2014, 09:59 AM
TJMS TJMS is offline
Mein Auto: 2002 745LI
Dear All
BMW quote 60 hours work to deal with the leaking front to back pipe you are all talking about
check this out the part is made to solve this issue permanently and it makes it for me at least a DIY job
https://www.agacoolantpipe.com/product/n62-coolant-pipe
Regards
Tom
Old 09-19-2014, 10:14 AM
The coolant leek issue video is here
The mystery oil leek ion this engine is either the cam cover gaskets which again is a cheep DIY job and if oil is getting onto the spark plugs then it is definitely this gasket their are two of them one for each cylinder head change the plugs and re-use the coil packs should be fine the oil is what is preventing the power getting to the spark plugs and the reason you get the engine check light coming on not the coil packs
or it is usually caused by a rubber seal which on some versions of the engine was used to connect to a oil cooler but not on the 745 where a rubber seal is used over the opening this always fails at higer milage and and or age
it is well hidden away check this video out to see where it is
search utube for
Oil Leak BMW 745Li E66, 545i E60 Front Cover N62 Engine
Old 09-19-2014, 10:16 AM
hope that is of some help to all you V8 lovers
