Old 10-19-2012, 10:24 PM
RichDeezy RichDeezy is offline
Mein Auto: 2001 BMW 530i E39
another window regulator question
so my window has fell off the clips as happend to BLUEBEE, after reading through her situation i thought it'd be a simple fix, but no, not only is it off the clips, the cable has come off the pulleys on my regulator, the motor works, and nothing else seems to be broke or damaged but i cant for the life of me get the cable to go on all 4 pulleys its driving me crazy not to mention the several cuts my hands have endured SMH....
has any one else had this tough of a time getting just the cable back on? i can hook it on to 3, yet i cant get the "slack" to make it around the last pulley...
Old 10-20-2012, 03:32 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
see the 2 springs near the regulator motor....compress that after looping the cables over all 4 pulleys.....that's the slack that you need.
this is from my lh front window.yes some manly strength is required...
Old 10-20-2012, 05:02 PM
will have to get back in there tomorrow and give that a go.
Old 10-20-2012, 05:36 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Can you remove a pulley while install?
Old 10-20-2012, 05:42 PM
i dont think they are removable, at least on mine it seemed the pulley was attatched to the regulator bar
Old 11-02-2012, 10:00 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
MatWiz pointed me directly to the answer to that question!
-> E39 (1997 - 2003) > How do we loosen tension on a BMW E39 front window regulator anyway?
Old 11-03-2012, 12:11 PM
bluebee's Avatar
I noticed, just now, doing research for this thread, that you seem to have removed one of the pulleys.
Can you tell us how you did it and whether you think the pulley can be put back on once removed (if a supplier could possibly be found for the pulley)?
ID:	348229   Click image for larger version
Old 11-03-2012, 04:24 PM
moots's Avatar
wat's dat noise
Mein Auto: '04 525i
hi blue.....the pulley i removed was the top rear (LH front window).the original plastic pink pulley broke.i got the white pullley(nylon) manufactured from a local engineering shop.to remove the original pulley,it has to be drilled out carefully,as the pulley post is swaged to the frame.putting it back was a pain but i was lucky to have a tiny bit of the "swage" left to be able to "put back" the pulley post to the frame.otherwise i would have a hell of a task to maneouver the pulley back in place while holding the pulley in it's post when re-installing the whole assy back to the door as the space is very constrained........
my advice is to get a used assy.much simpler.i did this coz i have time and coz i love wrenching.....
Old 11-03-2012, 05:03 PM
bluebee's Avatar
I got the white pullley(nylon) manufactured from a local engineering shop
Interesting. Thanks for the reply.
Searching, I found they sell the take-up spool pulleys for $1.25 each in batches of ten, as explained in this thread.
- How to loosen and tighten regulator cable tension (1)
But, I haven't found the 'rollers" yet.
drilled out carefully... a tiny bit of the "swage" left to be able to "put back"
Wow. I'm amazed! You basically 'broke' the 'rivet' and then pounded what was left back in place. I wonder if the bolt alone will work, without the rivet? Or, if another similar rivet can be used.
I do realize this is a BIG thick rivet, so it might be problematic to find a replacement.
Had I known about your success earlier, I would have tried it to fix this chip by replacing the roller (if I can find the roller):
a used assy is much simpler.
I understand.
However, I do like the idea of 'fixing' the thing ... or ... at least knowing HOW to fix it ... which is halfway there.
Assuming we destroy the rivet most of the time in removing the pulley, do you think a hardware store would have something similar to replace the rivet so that the replacement roller stays on the guide?
EDIT: I found this BMW front window regulator corner roller (with pin) - but it's for the E46:
Old 02-21-2013, 08:57 AM
bluebee's Avatar
For the record, this thread on how to replace the roller was added to the bestlinks today:
- How to replace just the window regulator rollers (1) (2)
Old 08-11-2014, 10:01 PM
bluebee's Avatar
There is potentially very useful information for those who chipped their brittle plastic window regulator rollers:
> E46 (1999 - 2006) > Do i need a new rear window regulator?
Originally Posted by catso View Post
I replaced my plastic rollers with brass ball-bearing patio door rollers I bought at Lowes. Cost me 4 bucks for two of them and they work like a charm.
Originally Posted by bluebee View Post
Was it these Lowe's rollers?
Or maybe these?
Or, maybe even these?
