Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW
General BMW
Use this forum to talk about general BMW news/stories and to chat with fellow enthusiasts about the direction that BMW is going in for their cars and/or motorcycles!
Old 10-20-2012, 11:16 AM
mousa 2003 bmw mousa 2003 bmw is offline
Mein Auto: 2003 bmw 330i
How to program a new key
How to program a new key for a 2003 BMW 330i. I bought a new virgin uncut original key from ebay i took and got it cut , tgen yook it to my mechanic so he can try programming it now it locks and unlocks the car but when you put it the ignition it starts the car for a minute then shuts off by itself ( by yhe way my original key only starts the car because im guessing the battery is did on it) is there a way i could fix my new key?
Old 10-20-2012, 02:48 PM
Mr.750's Avatar
Mr.750 Mr.750 is offline
A BMW, 7 Series of course
Mein Auto: Bay em dubya
I am pretty sure you cant. Dealer might be able to, its your best chance.
Old 10-21-2012, 06:53 AM
Dheilman Dheilman is offline
Dave
Mein Auto: 1998 Z3
I recently had to replace a warn key and the only way I could find was to order a new key from the dealer. The dealer will need proper ID and proof of ownership and will order the key by the VIN of the car. The new key will come pre-cut with the correct cut for the ignition, doors and truck locks and pre-programmed to match the code of the anti-theft chip. The reason your car will not run is because of the anti-theft and has nothing to do with the battery within the key. If your key has a built in light, the battery only operates the light.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=299148&dateline=1349724030
Old 11-25-2012, 06:07 PM
02MRoadster 02MRoadster is offline
Mein Auto: M Roadster
The chip keys need to be programmed either at the car or using a special machine hooked up to a computer with the software or a combination of both... Check with a locksmith or possibly a local hardware store and they should be able to program it. I work at Ace Hardware part-time and we can sometimes program the key, just depends on the car. I hope this helps.
Old 11-25-2012, 06:49 PM
Bigset3102 Bigset3102 is offline
Mein Auto: 528i
You have to order new key from dealer or authorized repair shop.
